RAMM AUDIO ELITE 8 Interconnect Cable OCC Copper Triple Shielding Ø9,2mm
RAMM AUDIO ELITE8 Interconnect Cable OCC Copper Triple Shielding Ø9,2mm
The Ramm Audio Elite8 is designed to provide the best possible analog connection to preserve the integrity of the transmitted signal. The result is a very low level of distortion and noise for a very transparent reproduction.
Reference : 15397
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
câble au mètre
Ramm Audio Elite8
Ramm Audio Elite8 Câble de modulation Cuivre OCC Triple Blindage Ø9.2mm
To achieve this result, the Elite8 incorporates geometrically organized OCC copper conductors with triple shielding and cotton filling. Each conductor is cryogenically treated to further improve transmission quality. It also uses the NBU (Noise Bypass Unit) technology with the use of a floating ground, which consists in separating the shield ground from the signal ground. The shield ground, connected only on one side, works like a Faraday cage, protecting the conductors from interference. A beautiful gold and black Nylon sheath finally dresses the cable, giving it excellent mechanical resistance and a beautiful design. This model is ideal for symmetrical connections.
Manufacturer's assembly instructions for wiring XLR connectors:
- The connection is made directly Pin to Pin for each of the 3 cores. The earth wire is optional, but can be connected to the body of the source connector.
Manufacturer's assembly instructions for wiring RCA connectors:
- Combine 2 cores for the (-) signal, and 1 core for the (+) signal. The earth wire is connected to the source connector.
Ramm Audio Elite 8 : Composition diagram
Ramm Audio cables comparison
Elite 8
Elite-XTRA
Elite 72 (E72)
Mozart2
Cable geometry
Air-Inside© geometry with multi-layer shielding for excellent transparency and resolution, with less distortion and noise
Conductors
Single-core OCC copper
Number of conductors
3 individually shielded conductors
2 individually shielded conductors
Conductor composition
3 wires of 0.65mm, 0.60mm and 0.55mm individually wrapped in silk thread
2 x 0.5mm PP-insulated wires
3 x 0.5mm bare wires
1 x 0.6mm bare wire
Drain wire
3 x 0.6mm OFC monocrystalline copper strands
3 x 0.5mm OFC monocrystalline copper strands
1 x 0.65mm OFC monocrystalline copper wire
Dielectric
Cotton filling
PP rods
Cotton filling
PP rods
Cotton filling
PP rods
Cotton filling
Conductors shielded by copper foil
Capacitance (pF/m)
140
203.51
203
155
Resistance (Ω/m)
0.024
0.03274
0.033
0.028
Inductance (µH/m)
1.4
1.31394
1.32
1.25
Characteristics
Natural, pure and transparent sound with smooth musicality and exceptional sound image. Quiet, excellent noise and interference rejection
Clean, natural signal transfer for dynamic performance with better-defined deep bass and smoother highs
Musical, transparent and smooth with excellent sound image
Sound image with highlighted voices. Natural sound with low distortion and noise
Connectors
Balanced connection, usually XLR
Single-ended connectors, usually RCA
Outer diameter
9.2mm
9.2mm
8.2mm
9mm
Product typeInterconnect cable
ConductorsOCC Copper
Cable diameterØ9.2mm
Triple shieldingAluminum-Mylar + PP
External sheathPVC
Cover sleeveBraided Nylon
ColorBlanc and gold
QuantitySold by the meter
Diameter (mm)9.2
Number of conductors3
Insulation materialPolypropylene (PP)
ShieldingYes
Section (mm²)N/A
Ground / ShieldingYes
7 reviews
Rodage imperatif
Excellent câble de modulation. Monté en xlr avec des neotech 06612, il se montre très charnu et délivré de beaux détails sur tout le spectre. Mérite des connecteurs de bonne qualité, ce qui m'a obligé a revoir cela, non pas que les neotech 06613 soient mauvais, mais peut être pas a la hauteur de ce câble.
Pendant son " rodage" ,il peut se montrer décevant mais en mûrissant, il est vraiment très bon.
This review has been posted for RAMM AUDIO ELITE 8 Interconnect Cable OCC Copper Triple Shielding Ø9,2mm
Superbe câble de modulation
Je dois reconnaître que ce câble RAMM Élite 8 est excellent. Après une période de rodage nécessaire, il est transparent avec de la matière, les instruments sont bien séparés, et l'image profonde.
Il remplace un câble Neotech nei 3004, qui demeure un très bon câble.
neutral, armonic and rich sound cable
this is a really good, wonderful cable.. it's outstanding considering it's price. i think it's at the same level of furutech occ cable at 1/3 the price.
the only cons it's about the internal conductor that are stiff, so it can be difficult to terminate (i have done a good job with viborg vr109g)
Excellent
Deuxième achat pour ces câbles.
Voir mon premier avis.
Malheureusement je n'ai pas pu les monter sur les RCA Elecaudio RC90 REDC.
Connecteurs de piètre qualité
Exceprionnel !!
Monté avec des fiches KLEI Silver en masse flotante.
Ce câble a détrôné des modèles à plus de 1200€.
Époustouflant.
Très dynamique , grande transparence, profondeur de la scène sonore, détaillé, bande passante , précis et clair, tous les critères d'un excellent câble sont réunis à un prix dérisoire.
Grande musicalité !!!
Une constante chez RAMM.
Même niveau que leur Amadeus 5 (utilisé en secteur )
Laissez tomber les pseudos référence à pas de prix, ne cherchez pas, tout est concentré dans ce câble
The Ramm Audio Elite8 is designed to provide the best possible analog connection to preserve the integrity of the transmitted signal. The result is...
