FURUTECH FP-200B (G) Banana Plug Phosphore Bronze Gold Plated 24k Ø5mm (Set x4)
FURUTECH FP-200B (G) Bananes BFA Bronze/Or (x2) Ø 5.0mm
3.5 / 5
By buying this product you get 27 loyalty points
Reference : 4755
95,00 €tax incl.
79,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
High performance banana plugs with 24k fine gold-plated bronze phosphorus contacts, a copper alloy containing 3.5 to 10% tin and up to 1% phosphorus. This metal is particularly appreciated in industry for its robustness against various stresses, wear and corrosion. Its use for the transit of low voltage signals is also justified by its low electrical resistance.
It is all the more efficient in its role as a conductor as it benefits here from the proprietary anti-magnetism process FURUTECH Alpha α, which takes place in 2 stages:
1- Cryogenization of metals at -250°C using liquid nitrogen in order to consolidate their molecular structure and significantly improve their conductivity.
2- Subjection of these same metals to a powerful magnetic field created by means of magnets arranged in rings, the attraction force of which is permanently controlled in order to leave no magnetic residue at the end of the treatment.
The FURUTECH FP-200Bs use a tube connection system to ensure their contact with the enclosure terminals. When the plug is connected, the cylinder, divided into two parts along a sinusoidal line, ensures constant and regular pressure over its entire surface.
Internally, the cable is fixed by means of 2 screws with a specially designed shape to maximise the contact surface and ensure a firm and durable hold. The FP-200B can also be welded for even greater reliability.
Their silver-coloured copper alloy body and the black/red FURUTECH screen printing used for marking complete a perfect finish in every respect.
Specifications:
  • 24k Gold Plated Bronze Phosphorus Contacts
  • Proprietary anti-magnetic treatment FURUTECH Alpha α
  • Accepts Cables Up to 4.9 mm diameter
  • Screw or Solder Plugs
  • Length of the body excluding the banana tip: 30.3mm.
  • Outside Body Diameter: 11.1mm Max.
  • Length Banana Tip Alone: 19.7mm
  • Diameter Banana Tip: 4.6mm
  • Total Length: 50mm
  • Marked with a Black / Red Color Code
  • Sold by Set of 4 paired plugs
https://www.audiophonics.fr/images2/4755_FURUTECH-FP-200B_1.jpg
https://www.audiophonics.fr/images2/4755_FURUTECH-FP-200B_3.jpg
https://www.audiophonics.fr/images2/4755_FURUTECH-FP-200B_4.jpg
https://www.audiophonics.fr/images2/4755_FURUTECH-FP-200B_2.jpg
Max cable diameter (mm)5.0
Mounting typeTo screw
ConnecticMale
ConnectorBanana
2 reviews
Très fragiles
Mes câbles HP (Fadièse) sont montés avec ces bananes, probablement très performantes au niveau audio mais extrêmement fragiles. Le moindre effort de levier lorsqu’elles sont branchées et elles se plient et cassent. J’ai du en changer trois au total. Heureusement la conception permet une soudure relativement aisée.
Une épaisseur de quelques dixièmes de mm du métal de la plume ne serait pas de trop...
 (3)
This review has been posted for FURUTECH FP-200B (G) Banana Plug Phosphore Bronze Gold Plated 24k Ø5mm (Set x4)
Ces fiches remplacent mes Yarbo 4 fois moins chères.
A l'écoute le gain est sensible ( aigus soyeux, basses préscises, scène sonore plus ouverte et "dépoussiérée"...).
Malheureusement, les vis fournis sont trops longues et dès que le cable est un peu gros il devient impossible de visser le corps cylindique ??!!
Il faut alors souder ou utiliser une gaine thermo !! Une vis plus courteest fournie... une seule??!!
Le problème est donc connu !!!!... et à moitié résolu !
 (4)
