FURUTECH FP-200B (R) Banana Plug Copper Rhodium Plated Ø5mm (Set x4)
FURUTECH FP-200B (R) Bananes BFA Bronze/Rhodium (x2) Ø 5.0mm
By buying this product you get 30 loyalty points
Reference : 6019
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
FHigh performance banana plugs with Rhodium-plated copper alloy contacts, a copper alloy containing 3.5 to 10% tin and up to 1% phosphorus. This metal is particularly appreciated in the industry for its robustness against various stresses, wear and corrosion. Its use for the transit of low voltage signals is also justified by its low electrical resistance.
It is all the more efficient in its role as a conductor since it benefits here from the proprietary anti-magnetism process FURUTECH Alpha α, which takes place in 2 stages:
1- Cryogenisation of metals at -250°C using liquid nitrogen in order to consolidate their molecular structure and significantly improve their conductivity.
2- Subjection of these same metals to a powerful magnetic field created by means of magnets arranged in rings, the force of attraction of which is permanently controlled in order to leave no magnetic residue at the end of the treatment.
The FURUTECH FP-200R use a tube connection system to ensure their contact with the enclosure terminals. When the plug is connected, the cylinder, divided into two parts along a sinusoidal line, ensures constant and regular pressure over its entire surface.
Internally, the cable is fixed by means of 2 screws with a specially designed shape to maximise the contact surface and ensure a firm and durable hold. The FP-200R can also be welded for even greater reliability.
Their silver-coloured copper alloy body and the black/red FURUTECH screen printing used for marking complete a flawless finish in every respect.
Specifications :
  • Rhodium-plated copper alloy contacts
  • Proprietary anti-magnetic treatment FURUTECH Alpha α
  • Accepts Cables Up to 5.0mm diameter
  • ength of the body excluding the banana tip: 30.3mm
  • Outside Body Diameter: 11.1mm Max.
  • Length Banana Bits Only: 19.7mm
  • Diameter Banana Bits: 4.6mm
  • Total Length: 50mm
  • Marked with a Black/Red Color Code
  • Sold by Pack of 4 paired plugs
https://www.audiophonics.fr/images2/6019/6019_FURUTECHFP-200R.jpg
Max cable diameter (mm)5.0
Mounting typeTo screw
ConnecticMale
ConnectorBanana
