VIABLUE TS2 Banana Plugs Gold Plated Ø5mm (Set x4)
Viablue TS2 Fiches Bananes (set x4) Ø 5.0mm
Viablue TS2 banana plugs use a tube connection system to ensure maximum contact with the speaker terminals. When connecting the banana plug to the terminal block, the cylinder, divided into two parts along a sinusoidal line, ensures a constant and regular pressure over its entire surface. This ensures an optimal contact surface and a firm hold of the banana plug.
Reference : 110
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
Viablue TS2
Viablue TS2 Fiches Banane Plaque Or Ø5mm (Set x4)
Viablue's TS series has been developed to offer a high-performance connector that can be adapted to any type of connection and terminal block. All connectors in this range are protected from short circuits by a transparent insulating sleeve. The connector accepts conductors up to 5mm in diameter, allowing mounting with large cables.
The cables are easily mounted in the TS plugs thanks to a simple and efficient screw mounting system (1.5mm hexagonal key sold separately). The cable receptacle narrows inside the plug so that the air flow is reduced when the cable is correctly inserted. This protects the cable conductor from oxidation.
For better protection of the cable conductor against oxidation, it is recommended to use Viablue OFC Copper cable protection tips (sold separately).
Product typeBanana plugs
Connectors platingGold 24k
ProtectionShort circuit
Max cable conductor diameterØ5mm
Connection typeTo screw
Total dimensions14mm x 46mm
Max cable diameter (mm)5.0
Mounting typeTo screw
ConnecticMale
ConnectorBanana
16 reviews
Belle qualité !!
Belle qualité de produit. Serrage efficace du câble et excellent contact dans le bornier. A recommander
PS : Il a déjà été signalé que la clé nécessaire est une Torx et non pas une Allen six pans....!!! Le descriptif est toujours à corriger !!!
This review has been posted for VIABLUE TS2 Banana Plugs Gold Plated Ø5mm (Set x4)
Belle qualité !!
Belle qualité de produit. Serrage efficace du câble et excellent contact dans le bornier. A recommander.
Good plugs
Good banana good looking and feeling for 5 mm cable
Very good looking products
Price and quality is nice . recommended.
Expédition rapide. Second achat de ces fiches, toujours excellente qualité.
Viablue TS2 banana plugs use a tube connection system to ensure maximum contact with the speaker terminals. When connecting the banana plug to the...
