Très bien ! Aucune dégradation du son et pratique pour essayer différentes enceintes.
Qualité de fabrication excellente.
Banana Plug Pure Red Copper ⌀4mm
With its VB-401, Viborg offers exceptional banana plugs, thanks to a design using particularly high-end materials.
Thus, the contact material of the terminal block is made of Pure Red Copper, which is not without attention. Indeed, copper is an excellent conductor, more efficient than gold. In addition, the use here of Red Copper, characterized by a "pink" tint, rather than classic Copper offers the connector an original and elegant aesthetic.
In short, these banana plugs are fully adapted to fit into a high-end HiFi audio system.
Conductor | Pure Red Copper |
Connection | To screw (Hexagonal socket screw 2mm) |
Max cable diameter | 4mm |
Diameters | Body : 8.9mm Contact : 4mm |
Length | 43mm |
Max cable diameter (mm) | 4.0 |
Mounting type | To screw |
Connectic | Male |
Connector | Banana |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | None |
Average votes 5.0 / 5 19 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Nicolas D.
ANDREJ S.
Thierry V.
Manfred D.
pierre B.
