WBT-0610Cu Banana Locking Plugs Pur Copper 10mm² (Set x4)
WBT-0610Cu Banana Plug Copper Ø 10mm (Set x4)
4.4 / 5
Reference : 4387
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Built on the recipes that have made the esteem of the WBT-0645 reference angled banana cards popular, the model WBT-0610Cu performance even further with the use of pure copper and an insulation Makrolon ®.
Provided with a key ensuring a secure connection conforming to CE standards the most demanding.
Extremely compact and easy to install thanks to its angle of 45 °, the WBT-0610Cu adapts to the most problematic configurations due to the lack of space or the positioning of the terminal blocks.
The tightening of the cable, with a maximum cross section of 10 mm², is carried out using 2 Torx screws ensuring constant pressure throughout the stripped portion for optimal contact.
Features:
  • Pure Copper Contacts
  • Insulation Makrolon ®
  • Tightening the cable with 2 screws Torx ™
  • CE-compliant detonator (can be easily removed)
  • Angle of inclination: 45 °
  • Cable Accepted: 10mm²
  • Overall length: 44 mm
  • Outside diameter: 12.5 mm
  • Sold by 4
  • Mark: 2 x red / 2 x white
WBT 0610 Cu
Max cable diameter (mm)6.5
Mounting typeTo screw
ConnecticMale
ConnectorBanana
7 reviews
excellent
Nice product from WBT ,well built could be a little bit cheaper but I still raccomand using this locking plugs
This review has been posted for WBT-0610Cu Banana Locking Plugs Pur Copper 10mm² (Set x4)
tip too short
It's great for tick wires. However there are several issues:
- the tip is very short. I wold have preferred a longer tip so that it can get fully into the amplifier terminal. It's short even for WBT terminals.
- At the price I would have expected a better mechanism instead of screws directly on the wire. A plate before the screws(i.e like on the SpeakOn plugs) would work much better(more surface area and less damage to the wire).
- At this price I would expect some kind of cable "pants" / "dressing" to isolate wire to the plug, preferably airtight.
In conclusion I'm very disappointed. High price and mediocre design.
déçu
En remplacement des WBT 0645 en laiton massif et très solide
j'ai voulu essayer les WBT 0610 Cu très légères et pour cause très peu de cuivre la structure étant en plastic elles me paraissent pas solides et le comble elles tiennent pas dans les borniers enceintes alors que les précédentes sont parfaitement verrouillées .
Certes la musicalité est un soupçon meilleure certainement du à l'apport du cuivre mais le compte n'y est pas, je regrette mon achat .
 (4)
super produit
Les fiche banane WBT cuivre pur il sont magnifique pour des câble section 10mm très bien merci !
Banane solide et performante
Elle permet de brancher des câbles épais comme les 8vs. Solide, bien concue elle n'a pas modifié la signature sonore de mon câble
