RAS, bon accu Lithium-Ion
Warning: these batteries do not have electronic protection circuit. It must be used with a BMS (Battery Management System) capable of interrupting the charging and discharging depending on the state of the cell. You will find such a circuit with battery cradle and connectivity here..
This 26650 battery is ideal for projects that require a transportable power supply. This massive battery format can both be used with devices that require long battery life and devices that require high energy discharge (15A max).
Thanks to their ease of use, the individual batteries of this type are particularly appreciated in the DIY scene. Easily interchangeable and renewable, they make effective, long-lasting and economical power solutions.
Type | Accumulator |
Format | 26650 (cylindrical) |
Capacity | 5200mAh |
Rechargeable | Yes |
Chemistry | Lithium Ion (IMR) |
Nominal voltage | 3.7V |
Max voltage | 4.2V |
Min Voltage | 2.5V |
Max discharge current | 15A |
Connector | Flat Top |
Dimensions | 26.8 x 66.7mm (+/- 0.2) |
Weight | 95.0g |
Package Contents | |
battery 26650 | x1 |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
