EIZZ EZ-301 Gold plated OFC Copper Binding posts Ø16mm x 61mm (Pair)
EIZZ EZ-301 Gold plated OFC Copper Binding posts (Pair)
EIZZZ AUDIO offers excellent quality products made of innovative raw materials with top-of-the-range finishes. These gold-plated OFC Copper terminals have a fiberglass body.
4.8 / 5
Reference : 9899
11,90 €tax incl.
9,92 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Eizz EZ-301
Eizz EZ-301 Borniers Cuivre OFC plaqué Or Ø16mm x 62mm (La paire)
EIZZZ AUDIO offers excellent quality products made of innovative raw materials with top-of-the-range finishes. These gold-plated OFC Copper terminals have a fiberglass body. They accept banana plugs and forks.
Product typeSpeaker binding posts
Contacts materialOFC Copper
PlatingGold
InsulationGlass fiber
Panel cutout diameter7.8mm
Total diameter16mm
Max panel thickness10mm
Total length61mm
Accepts banana plugsYes - 4mm
Accepts spade connectorsYes - 7mm
Wrench type for nut screwing12mm
QuantitySold per pair (1 red binding post + 1 black binding post)
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)10.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
20 reviews
Verry good with minor issues.
It does not seem to have any iron in the conducting part of the connector. Just the golden cock ring has some iron and I just cut it of (seems stupid to include it, the connector looks better all black) as it could act as a small filter (like a ferrite bead). The cap is aluminium but I dont see how it could affect the sound, a better solution may have been plastic like WBT connectors. These connectors are my go to as it seems to not affect the sound (compared with just wire) and are way cheaper than WBT.
This review has been posted for EIZZ EZ-301 Gold plated OFC Copper Binding posts Ø16mm x 61mm (Pair)
Très très bien
Marque et produit sérieux ! Rapport qualité prix sans commentaire !
Absolument recommandé.
Very good
Connections are often underestimated by audiophiles. Dirty rca inputs and poor quality binding posts degrade the audio signal more than one might believe. I replaced the crappy brass-made binding posts on my speakers (cornscala type d) with these Eizz and the difference was stunning. Better imaging, more extension and presence, no traces of harshness, more silence between notes. One of the best buys in my music and hifi lover carrer! Excellent product and excellent service by Audiophonics!
Du sérieux!!!
Je confirme la qualité de construction et c'est bien du cuivre...
Pour passer mes câble 2,5mm j'ai percé les fiches avec un forets et c'est parfait et toujours solide (il y a une surface plane assez large)
Pas besoin de se tracasser pour l'encoche ou le détrompeur il suffit de changer l'ordre des rondelles de couleurs...
La soudure est parfaite, un bon rapport qualité prix
Pas mieux pour le prix
Qualité super! Un des rares bornier avec une faible masse, de plus c’est du vrai cuivre sous le placage or. Le prix est 10x moins cher que certaine marque pour la même qualité du conducteur… Je vous le recommande pour tout type de haut parleur si vous avez prit un bon câble pour plus de transparence, ce bornier sera faire passer le signal parfaitement.
EIZZZ AUDIO offers excellent quality products made of innovative raw materials with top-of-the-range finishes. These gold-plated OFC Copper...
