Binding posts Silver Plated Copper (set x4)
KLEI Harmony Classic binding posts offer excellent design quality for enhanced performance, based on a certain know-how, the fruit of the brand's many years of experience. For example, the contacts of these sockets are made of copper with silver plating, ensuring an optimum conductivity of 101% IACS. The design of these connectors focuses on signal integrity by eliminating the causes of possible interference, such as eddy current or capacitive reactance.
For the body of the subbases, an ultra heat resistant polymer was used, cancelling the disturbances that can be induced by a metal structure. The mass of the connectors is also reduced and calculated by KLEI in order to limit the skin effect as well as EMF and RF interference.
Thus, these mounts will fit perfectly into your high-end DIY setups and contribute to the signal transmission quality of your audio system.
Product type | binding postss |
Contacts material | Copper |
Contacts plating | Silver |
IACS Conductivity index | > 101% |
Maximum diameter of bare wire rope accepted | 4mm |
Connection type | To solder |
Quantity | Sold by 4 (2 plug with red ring, 2 plug with white ring) |
Mounting type | To weld |
Connectic | Female |
Max panel thickness (mm) | N/A |
Accepts Banana Plugs | Yes |
Connector | Speaker terminal |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Silver |
