ARYLIC UP2STREAM PRO V2 2.4G WiFi Bluetooth 5.0 receiver to I2S Multiroom 192kHz
4.5 / 5
Reference : 14467
64,90 €tax incl.
54,08 € tax excl.
This product is replaced by the new model : ARYLIC UP2STREAM PRO V3 WiFi / bluetooth receiver
Up2Stream Pro V2
Audio Receiver Module WiFi / Bluetooth, LAN, I2S
This Up2Stream Pro Module is a wireless receiver (wifi and bluetooth 5.0) and wired (LAN) to I2S. It is compatible with Spotify, Airplay, DLNA, Internet radio, Web streaming, USB pen, NAS. It allows you to add a full-media oriented connectivity to your hi-fi system or active speakers.
The circuit is designed to allow all kinds of complex integrations: multiroom, multi-zone streaming and stereo synchronization.
The Up2Stream Pro V2 module thus provides complete network connectivity to anticipate every scenario and allow you to make the best choices for excellent audio quality.
It supports Airplay technology, DLA, Spotify Connect, Qplay. This will be used as well to get the audio stream from a web platform, but also from local files from a phone or a computer.
The RJ45 input will be particularly useful for situations requiring long distances, providing access to stable and reliable network even if the wifi router is saturated or inefficient.
The module supports the Bluetooth 5.0 connection with a very advantageous range up to 30 meters.
The Dual Bluetooth & WiFi connectivity will be very useful for audiophiles DIYer who have complex sound systems or heavily modified installations: all problem of compatibility may be circumvented by passing from one technology to another. Thus, a user wishing to connect to a platform that is not supported by the app or the regular Wireless protocols can always fallback to bluetooth streaming with playback from a smartphone without performing additional  hardware modification.
Please note, to achieve the most accurate audio quality, systematically prefer wifi and the dedicated application to get the best sound reproduction available on this module.
The active entry is indicated by a set of colored diodes.
4Stream Application
The essential features of the module can be controlled from a smartphone or tablet via the 4STREAM application. The latter allows to easily stream audio from the phone memory and control advanced functions such as multi-room, multi-zone or synchronized platform pairing of multiple speakers / channels.
The application also provides several EQ options and control playback options, volume ... etc.
WiFiIEEE802.11 b / g / n 2.4G
LANSingle RJ45 10 / 100M
BluetoothBT 5.0
Frequency response20Hz-20kHz
Power supplyMicro-USB / Terminal Screw
Analog output3.5mm to (0dB @ 1Vrms)
4 line pin (L, GND, GND, R)
Analog inputs3.5mm to (0dB @ 1Vrms)
Digital outputI2S
IR ProtocolIR (NEC protocols)
SNR91dB
THD0.03%
File FormatsFLAC, MP3, AAC, AAC +, ALAC, APE, WAVE
Sample RateDecoding upto 24bit, 192kHz
ProtocolsAirplay, DLNA, Spotify Connect, Qplay, UPnP,
Streaming sourcesSpotify, Deezer, Tidal, Qobuz, iHeartRadio, Napster, Web Radio
App4STREAM ( App store & Google Play store)
ControlSmartphone IOS / Android
PC with iTunes / Foobar2000
Remote I / R
Key functionsMultiroom / Multizone
ReStream
stereo pairing
Dimensions88 * 50 * 15mm
Weight90g
InputBNC
InputRJ45
InputWiFi
InputJack 3.5mm
OutputI2S
2 reviews
Genial!
Ce petit module est tout simplement fantastique fonctionne a merveille, super simple a installer. Ce que je trouve super c'est que l'on peux faire quelque chose de très simple ou si on a la courage et un peu de savoir faire des choses plus complètes.
Seul petit défaut que j'ai trouvé c'est au niveau de l’application, il n'y a pas la possibilité de l'afficher au format paysage (tablette).
This review has been posted for ARYLIC UP2STREAM PRO V2 2.4G WiFi Bluetooth 5.0 receiver to I2S Multiroom 192kHz
Enorme potentiel, sera associé à une carte optique/coaxiale AES/EBU en attente de montage
Pierre D
