TINYSINE TSA5000 Bluetooth transmitter module 5.0 apt-X
This ultra-compact and light-weight module has an analog input and a Bluetooth encoder / transmitter. This technology is particularly useful when you need to connect the audio output of a TV, radio or a computer to a Bluetooth receiver but only have an ordinary audio out.
1.0 / 5
Reference : 13840
24,90 €tax incl.
20,75 € tax excl.
Shipping from France
Billing in France
Technical support in France
tsa5000-module-emetteur-bluetooth-50-apt
Module Bluetooth 5.0 transmitter TSA5000
If the main purpose of this module is to minimize cable jungles in the living rooms by allowing non-wired connections with devices not having this native functionality,.Ease of integration and its versatile size will enable it to operate in a variety of scenarios (eplacing / upgrading an existing tx unit, installation in a powered-box for occasional uses ... etc.).
The TSA5000 chip supports Bluetooth 5.0 standard, as well as the apt-X protocol and apt-X Low Latency for maximum audio quality.
Intuitive use
As far as powering, pairing and installing the module are conccerned TSA5000 shines by its simplicity. It is powered with ease via a micro-USB port from a USB wall adapter  (smartphone charger type).
No driver is required: the module is configured internally for all operations relating to decoding / encoding of the audio stream to a digital wireless signal. The user only has to connect the audio source to its 3.5mm connector to the module on and push the single button for 5 to 7 seconds to pair the module with the receiving device.
Bluetoothv5.0
SupportaptX, aptX Low Latency, SBC and AAC
Standard5 Bluetooth + EDR
ProtocolA2DP
Output PowerClassII
Dimensions44.5x44x12mm
Weight10g
InputJack 3.5mm
OutputBluetooth
"noise-gate" activée sur le microcontroleur Qualcomm
Le défaut de documentation est patent, l'option "noise-gate" a été activée sur le microcontrôleur Qualcomm chargé d'encoder le signal audio. Résultat : le son est coupé dans les parties légères ou faibles. Cela est très flagrant sur la musique de la renaissance ou des sons de la nature alors qu'un transmetteur bluetooth classique comme un smartphone ne présente pas ce problème rédibitoire.
This review has been posted for TINYSINE TSA5000 Bluetooth transmitter module 5.0 apt-X
This ultra-compact and light-weight module has an analog input and a Bluetooth encoder / transmitter. This technology is particularly useful when...
