Bluetooth 4.2 Receiver Board aptX CSR64215
This Bluetooth 4.2 receiver module is equipped with a CSR64215 chip supporting the aptX protocol. This technology increases the transmission rate and improves the stability of the signal for clean playback.
Reference : 13523
19,90 €tax incl.
16,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
Récepteur Bluetooth
Module Récepteur Bluetooth 4.2 aptX CSR64215
This Bluetooth 4.2 receiver module is equipped with a CSR64215 chip supporting the aptX protocol. This technology increases the transmission rate and improves the stability of the signal for clean playback. The module also incorporates a low noise AOP JRC 5532DDD mounted on DIP8 and therefore interchangeable.
On the connector side, the module is simple and efficient with power supply via Micro USB and output on a 3.5mm jack connector. For entry, simply stream your music from your smartphone and enjoy.
Product typeBluetooth receiver
Bluetooth version4.2
Transmission protocolaptX
InputBluetooth 4.2
Output1x Jack 3.5mm
Power supply5VDC 500mA via Micro USB (power supply not included)
Dimensions61.7 x 62.3 x 15.3mm
OutputJack 3.5mm
This Bluetooth 4.2 receiver module is equipped with a CSR64215 chip supporting the aptX protocol. This technology increases the transmission rate...
