WONDOM BRB4 AA-AB41155 aptX Bluetooth 4.0 Audio Receiver Board CSR8670 Car Audio
SURE BRB4 AA-AB41155 Apt-X Bluetooth 4.0 Audio Receiver Board 12V Car Audio
The Bluetooth 4.0 aptX Wondom BRB4 receiver will allow you to stream your music via Bluetooth while enjoying excellent sound quality. Indeed, this module ensures low noise and low distortion. In addition, its aptX, A2DR and +EDR technologies provide optimal transmission quality and stability.
Reference : 12166
28,90 €tax incl.
24,08 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
Wondom BRB4 AA-AB41155
Wondom BRB4 AA-AB41155 Module récepteur Bluetooth 4.0 aptX CSR8670 Car Audio
The Bluetooth 4.0 aptX Wondom BRB4 receiver will allow you to stream your music via Bluetooth while enjoying excellent sound quality. Indeed, this module ensures low noise and low distortion. In addition, its aptX, A2DR and +EDR technologies provide optimal transmission quality and stability.  Being able to receive a voltage of 12V, this module is also ideal for all Car Audio installations.  You can therefore connect the module directly to the electrical system of your car, without having to use a voltage booster.
Wondom BRB4 AA-AB41155 Module récepteur Bluetooth 4.0 aptX CSR8670 Car Audio Wondom BRB4 AA-AB41155 Module récepteur Bluetooth 4.0 aptX CSR8670 Car Audio
Product typeBluetooth receiver module
Bluetooth chipCSR8670
Bluetooth version4.0
Supported technologiesaptX, +EDR, A2DP
Outputs1x RCA
1x Jack 3.5mm
Bluetooth transmission distanceUp to 10m
Gain43dB
Input sensitivity (RMS)Jack 3.5mm @ 6Ω, 100W, 1kHz : 294mV
RCA @ 6Ω, 100W, 1kHz : 496mV
Input impedance19kΩ
Output power@ 6Ω, THD+N=1% : 82W
@ 6Ω, THD+N=10% : 100W
Supported sampling rateUp to 24bit 96kHz
Frequency response (@ ±3dB, 6Ω)20Hz - 20kHz
THDJack 3.5mm @ 6Ω, 1W, 1kHz : 0.05%
RCA @ 6Ω, 1W, 1kHz : 0.042%
Output noise level620µV
SNR@ 82W, 6Ω, THD+N=1%, RCA : 82dB
Switching frequency370kHz
Impédance de charge minimum6Ω
Efficiency@ 100W, 6Ω : from 86% to 91%
Max current@ 200W, 6Ω : 8A
Control via buttonsExternal buttons supported
Possibility to add an antenna
Possibility to add status LEDs
Customizable PIN code
Power supply9 to 24VDC
Dimensions9.1 x 6.9cm
The Bluetooth 4.0 aptX Wondom BRB4 receiver will allow you to stream your music via Bluetooth while enjoying excellent sound quality. Indeed, this...
