SURE BRB4 aptX Bluetooth 4.0 Audio Receiver Board Wireless with control buttons
SURE Apt-X Bluetooth 4.0 Audio Receiver Board Wireless DIY
Reference : 11200
28,90 €tax incl.
24,08 € tax excl.
This product is no longer in stock
Sure offers an ultra-modern receiver (Bluetooth 4.0 and Apt-X) with stereo analog output and control buttons.
These 5 buttons have the function: Previous and Next Music / Volume plus and minus / Play and Pause.
This DIY module is ideal for adding bluetooth wireless connectivity to any audio project. Its ability to be powered by 12VDC allows it to add the Bluetooth functions to any vehicle that would be devoid of origin.
Ccompatible with all Bluetooth 4.0 AD2P devices, it offers CD-quality quality playback with a low compression ratio. Thus, FLAC, Apple Lossless or PCM audio files are rendered almost perfectly. When files natively in MP3 or AAC (with a rate less than 350Kbits / sec), they are transmitted without decoding and without any degradation.
Byt its compact design and ease of implementation, this receiver will allow you to listen to your favorite songs on your audio system from any Bluetooth source. Either the vast majority of Smartphone, Tablet PC, iPhone, iPad ...
Possibility to rename the bluetooth pairing name for free from 10 quantities purchased.f = "http://www.audiophonics.com/contact us" target = "_ blank">Contact Usfor more information.
Find all the detailed features of thishref = "http://store3.sure-electronics.com/documents/sales/brochure/Bluetooth%20Audio%20Receiver%20Board.pdf" target = "_ blank">module BRB4 Bluetooth 4.0 here.
Specifications BRB4:
  • Chipset CSR8670
  • Signal to Noise Ratio (SNR): 92dB to 12V DC
  • Outputs: Analog RCA Stereo
  • Outputs 4 PIN 2.54mm
  • Bluetooth: 4.0 apt-X (+ AD2P) Low latency
  • Connector Power supply: Jack DC (2.1 / 5.5mm) 9 to 24 VDC
  • Power connector on screw terminal block VCC and GND
  • Bluetooth Profiles: V4.0 + EDR / A2DP
  • Supplied without AC adapter
indeedPower adapter Power supply 100-240V to 12V 2A.
ComponentCSR8670
Channel2 channels (Stéréo)
Colissimo - TNT - SoColissimo
0 reviews
bien
This review has been posted for SURE BRB4 aptX Bluetooth 4.0 Audio Receiver Board Wireless with control buttons
