AUDIOPHONICS Bluetooth Receptor 5.0 AptX HD CSR8675 / DAC PCM5102A 24Bit / 96kHz
AUDIOPHONICS LHDC Bluetooth Receptor 5.0 AptX HD LHDC CSR8675 / DAC ES9018K2M
This tiny Bluetooth 5.0 receiver is the ideal solution for integrating wireless connectivity in audio installations. It supports aptx HD standard and thus enables you to integrate the latest Lossless Bluetooth technology with minimal efforts and space.
Reference : 14210
55,90 €tax incl.
46,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
Bluetooth 5.0 Receiver
Aptx HD / CSR8675 / DAC PCM5102A 96kHz 24bit
The circuit carry its own reference chip PCM5102A to ensure a high-level digital / analog conversion. The sound benefits  low distorsion (93dB THD), high dynamic range of 112dB and a Signal / Noise ratio of 112dB as well.
A Qualcomm chip CSR8675 is in charge of receiving the Bluetooth stream. The latter contributes significantly to the excellent audio quality through the Aptx HD support for lossless audio transmission.
Very easy to install, the device is powered by a USB-C port on the rear panel and offers a 3.5mm output jack on the front.
Caution : the power supply / power cable (USB-C to USB-A) are not included with this product
OPA1612
The receiver output stage uses an operational amplifier OPA1612. This model is particularly appreciated for its extremely low noise level with a distortion rate of 0.000015% at 1kHz and a spectral density of noise of 1.1VJHz.
TypeBluetooth receiver
StandardBluetooth 5.0
DAC chipPCM5102A
Bluetooth chipCSR8675
Power SupplyDC 5V USB-C (not included)
NormsaptX, aptX Low Latency, aptX HD, MP3, AAC, SBC
Dimensions63 x 67 x 20 mm
OutputJack 3.5mm
DAC / ADC ChipPCM5102
Supported Bluetooth codecsAAC
Supported Bluetooth codecsSBC
2 reviews
super qualité audio 24bits 384 kHz
J'ai 3 modules TX/RX Bluetooth et celui ci fournit la meilleurs qualité audio et de loin. Un simple chargeur USB de tel est suffisant pour le faire fonctionner.
This review has been posted for AUDIOPHONICS Bluetooth Receptor 5.0 AptX HD CSR8675 / DAC PCM5102A 24Bit / 96kHz
Fait l'affaire !
Fonctionne parfaitement, le son est bon. Parfait pour le pour le prix.
P.S. à l'attention d'audiophonics : l'alimentation que vous préconisez sur votre site n'est pas adaptée au récepteur car ce dernier possède une entrée en USB C alors que l'alim. est encore avec l'usb première génération. Donc l'alimentation que j'ai reçue ne me sert à rien, dommage.
This tiny Bluetooth 5.0 receiver is the ideal solution for integrating wireless connectivity in audio installations. It supports aptx HD...
