This small Bluetooth 5.0 receiver and transmitter offered at a low price will allow you to broadcast your music wirelessly to a classic audio system or a headphone for example. In addition to the bi-directional Bluetooth, the device provides a Micro SD slot as well as a stereo RCA and Jack 3.5mm input/output. It also has a display showing pairing information for easy and convenient use.
Use of the buttons :
- Volume control: Long press on "Previous music" or "Next music"
- Music selection: Single press on "Previous music" or "Next music"
- Play / Pause: Single press on "M"
- Switching from receiver to transmitter mode and vice versa: Long press on "Previous music" and "Next music" at the same time
- Search again in transmitter mode: Double press "M".
The receiver is identified by the name "C39S".
Product type | Bluetooth receiver and transmitter |
Inputs | Bluetooth 5.0 1* Stereo RCA 1* Jack 3.5mm 1* Slot Micro SD |
Outputs | Bluetooth 5.0 1* Stereo RCA 1* Jack 3.5mm |
Supply voltage | 5VDC 1A |
Dimensions (L*P*H) | 69*69*23.5mm |
Color | Black |
Package | 1* Bluetooth receiver/transmitter 1* RCA to Jack 3.5mm cable 1* Jack 3.5mm cable 1* USB-A to USB-C cable |
Input | RCA |
Input | Bluetooth |
Input | Jack 3.5mm |
Input | Micro SD |
Output | RCA |
Output | Bluetooth |
Output | Jack 3.5mm |
DAC / ADC Chip | NC |
Color | Black |
Transmission / Reception protocol | Bluetooth |
Supported Bluetooth codecs | N/A |
