MUNDORF L071 Self Air 0.71mm 3.90mH
MUNDORF L071 Self à Air 0.71mm 3.90mH
Reference : 4252
8,60 €tax incl.
7,17 € tax excl.
MUNDORF L071 Air Cored Coil 0.71mm 3.90mH
Air cored coils are, for physical reasons,unbeatable as far as accurate pulseandfreedom from distortionare concerned.
For this reason, for all the purists, we stock air cored coils withwire diameters of up to 3.0 mm.
It is also possible in this way to creategreater inductances with relativelylow internal resistance.
Vacuum impregnationalso leads in the air cored coils described here in greater detail and spatial quality in the reproduction of music.
Technical Specifications:
  • Electrolytecopper 99.99%
  • Pure Coil forms: PA, glass fiber reinforced
  • Tolerance:Max 3%, typically 1.5%
https://www.audiophonics.fr/images2/4539-4567_MUNDORF-L100-140_1.jpg
https://www.audiophonics.fr/images2/4539-4567_MUNDORF-L100-140_3.jpg
https://www.audiophonics.fr/images2/4539-4567_MUNDORF-L100-140_4.jpg
Wire Diameter / mm
L / mH
R / Ohm
Max power (8 Ohm)
Dimensions
L071-0050.710.050.19
35 W
25 x 10mm
L071-0100.710.100.23
31 W
25x 10mm
L071-0120.710.120.2542 W 36 x 10mm
L071-0150.710.150.2839 W36 x 10mm
L071-0180.710.180.3138 W36 x 10mm
L071-0220.710.220.3437 W36 x 10mm
L071-0270.710.270.3934 W36 x 10mm
L071-0330.710.330.4333 W 36 x 10mm
L071-0390.710.390.5129 W36 x 10mm
L071-0470.710.470.5821 W 30 x 20mm
L071-0560.710.560.6420 W30 x 20mm
L100-0680.710.680.7120 W30 x 20mm
L100-0820.710.820.8118 W30 x 20mm
L100-1000.711.00.9117 W 30 x 20mm
L100-1200.711.21.018 W40 x 20mm
L100-1500.711.51.117 W 40 x 20mm
L100-1800.711.8 1.217 W40 x 20mm
L100-2000.712.01.316 W40 x 20mm
L100-2200.712.21.416 W 40 x 20mm
L100-2700.712.71.515 W40 x 20mm
L100-300 0.713.01.615 W40 x 20mm
L100-3300.713.31.814 W40 x 20mm
L100-3900.713.92.016 W58 x 18mm
L100-4700.714.72.216 W58 x 18mm
L100-5600.715.62.416 W58 x 18mm
L100-6800.716.82.715 W58 x 18mm
L100-8200.718.23.114 W58 x 28mm
L100-10000.7110.03.613 W58 x 28mm
L100-12000.7112.03.914 W70 x 29mm
L100-15000.7115.04.513 W70 x 29mm
L100-18000.7118.05.013 W70 x 29mm
L100-22000.7122.05.712 W70 x 29mm
L100-27000.7127.06.411 W70 x 29mm
Colissimo - TNT - SoColissimo
