MUNDORF L140 Air Cored Coil 1.40mm 0.15mH
Air cored coils are, for physical reasons,unbeatable as far as accurate pulseandfreedom from distortionare concerned.
For this reason, for all the purists, we stock air cored coils withwire diameters of up to 3.0 mm.
It is also possible in this way to creategreater inductances with relativelylow internal resistance.
Vacuum impregnationalso leads in the air cored coils described here in greater detail and spatial quality in the reproduction of music.
P>
Technical Specifications:
P>
Wire Diameter / mm Font> | L / mH | R / Ohm | Max power (8 Ohm) | Dimensions | |
L140-010 | 1.40 | 0.10 | 0.07 | 267 W | 40 x 20mm |
L140-012 | 1.40 | 0.12 | 0.08 | 265 W Font> | 40 x 20mm |
L140-015 | 1.40 | 0.15 | 0.10 | 237 W | 40 x 20mm |
L140-018 | 1.40 | 0.18 | 0.11 | 251 W | 58 x 18mm |
L140-022 | 1.40 | 0.22 | 0.12 | 248 W | 58 x 18mm |
L140-027 | 1.40 | 0.27 | 0.13 | 245 W | 58 x 18mm |
L140-033 | 1.40 | 0.33 | 0.15 | 227 W Font> | 58 x 18mm |
L140-039 | 1.40 | 0.39 | 0.16 | 239 W | 58 x 18mm |
L140-047 | 1.40 | 0.47 | 0.19 | 213 W Font> | 58 x 18mm |
L140-056 | 0.56 | 0.20 | 192 W | 58 x 22mm | |
L140-068 | 1.40 | 0.68 | 0.23 | 197 W | 58 x 28mm |
L140-082 | 1.40 | 0.82 | 0.26 | 184 W | 58 x 28mm |
L140-100 | 1.40 | 1.0 | 0.30 | 168 W Font> | 58 x 28mm |
L140-120 | 1.40 | 1.2 | 0.34 | 164 W | 70 x 29mm |
L140-150 | 1.40 | 1.5 | 0.38 | 156 W Font> | 70 x 29mm |
L140-180 | 1.40 | 1.8 | 0.43 | 146 W | 70 x 29mm |
L140-200 | 1.40 | 2.0 | 0.45 | 148 W | 70 x 29mm |
L140-220 | 1.40 | 2.2 | 0.46 | 152 W Font> | 70 x 29mm |
L140-270 | 1.40 | 2.7 | 0.51 | 133 W | 77 x 28mm |
L140-300 | 1.40 | 3.0 | 0.55 | 131 W | 77 x 28mm |
L140-330 | 1.40 | 3.3 | 0.58 | 123 W | 77 x 28mm |
L140-390 | 1.40 | 3.9 | 0.65 | 103 W | 77 x 28mm |
L140-470 | 1.40 | 4.7 | 0.80 | 98 W | 70 x 59mm |
L140-560 | 1.40 | 5.6 | 0.89 | 86 W | 70 x 59mm |
L140-680 | 1.40 | 6.8 | 1.1 | 89 W | 70 x 59mm |
L140-820 | 1.40 | 8.2 | 1.1 | 94 W | 70 x 59mm |
L140-1000 | 1.40 | 10.0 | 1.2 | 93 W | 88 x 75mm |
L140-1200 | 1.40 | 12.0 | 1.4 | 100 W | 88 x 75mm |
L140-1500 | 1.40 | 15.0 | 1.6 | 13 W | 105 x 92mm |
