MUNDORF L140 Self to Air 1.40mm 4.70mH
MUNDORF L140 Self à Air 1.40mm 4.70mH
Reference : 1665
35,90 €tax incl.
29,92 € tax excl.
Available
Shipping date: 23-01-2019.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
MUNDORF L140 Air Cored Coil 1.40mm 4.70mH
Air cored coils are, for physical reasons,unbeatable as far as accurate pulseandfreedom from distortionare concerned.
For this reason, for all the purists, we stock air cored coils withwire diameters of up to 3.0 mm.
It is also possible in this way to creategreater inductances with relativelylow internal resistance.
Vacuum impregnationalso leads in the air cored coils described here in greater detail and spatial quality in the reproduction of music.
Technical Specifications:
  • Electrolytecopper 99.99%
  • Pure Coil forms: PA, glass fiber reinforced
  • Tolerance:Max 3%, typically 1.5%
https://www.audiophonics.fr/images2/4539-4567_MUNDORF-L100-140_1.jpg
https://www.audiophonics.fr/images2/4539-4567_MUNDORF-L100-140_3.jpg
https://www.audiophonics.fr/images2/4539-4567_MUNDORF-L100-140_4.jpg
Wire Diameter / mm
L / mH
R / Ohm
Max power (8 Ohm)
Dimensions
L140-0101.400.100.07
267 W
40 x 20mm
L140-0121.400.120.08265 W 40 x 20mm
L140-0151.400.150.10237 W40 x 20mm
L140-0181.400.180.11251 W58 x 18mm
L140-0221.400.220.12248 W58 x 18mm
L140-0271.400.270.13245 W58 x 18mm
L140-0331.400.330.15227 W 58 x 18mm
L140-0391.400.390.16239 W58 x 18mm
L140-0471.400.470.19213 W 58 x 18mm
L140-0561.40 0.560.20192 W58 x 22mm
L140-0681.400.680.23197 W58 x 28mm
L140-0821.400.820.26184 W58 x 28mm
L140-1001.401.00.30168 W 58 x 28mm
L140-1201.401.20.34164 W70 x 29mm
L140-1501.401.50.38156 W 70 x 29mm
L140-1801.401.80.43146 W70 x 29mm
L140-2001.402.0 0.45148 W70 x 29mm
L140-2201.402.20.46152 W 70 x 29mm
L140-2701.402.70.51133 W77 x 28mm
L140-3001.403.00.55131 W77 x 28mm
L140-330 1.403.30.58123 W77 x 28mm
L140-3901.403.90.65103 W77 x 28mm
L140-4701.404.70.8098 W70 x 59mm
L140-5601.405.60.8986 W70 x 59mm
L140-6801.406.81.189 W70 x 59mm
L140-8201.408.21.194 W70 x 59mm
L140-10001.4010.01.293 W88 x 75mm
L140-12001.4012.01.4100 W88 x 75mm
L140-15001.4015.01.613 W105 x 92mm
Colissimo - TNT - SoColissimo
excellente self
Une des meilleures self que j'ai pu avoir, du grave sans limite, mais surtout du medium riche et raffiné avec beaucoup de profondeur. Je les utilise en basse reflex sur des TAD.
This review has been posted for MUNDORF L140 Self to Air 1.40mm 4.70mH
