MUNDORF L300 Air Cored Coil 3.00mm 2.00mH
MUNDORF L300 Self à Air 3.00mm 2.00mH
5110
139,40 €tax incl.
116,17 € tax excl.
Air cored coils are, for physical reasons, unbeatable as far as accurate pulse reproduction and freedom from distortion are concerned.
For this reason, for all the purists, we stock air cored coils with wire diameters of up to 3.0 mm.
It is also possible in this way to create greater inductances with relatively low internal resistance.
Vacuum impregnation also leads in the air cored coils described here to greater detail and spatial quality in the reproduction of music.
Technical Specifications :
  • Electrolyte copper 99.99 %
  • Pure Coil forms : PA, glass fibre reinforced
  • Tolerance : Max 3%, typically 1.5%
https://www.audiophonics.fr/images2/4539-4567_MUNDORF-L100-140_1.jpg
https://www.audiophonics.fr/images2/4539-4567_MUNDORF-L100-140_3.jpg
https://www.audiophonics.fr/images2/4539-4567_MUNDORF-L100-140_4.jpg
Models Wire diameter /mm
L/mH
R / Ohm
Dimensions
L300-0103.000.100.02
88 x 75 x 61mm
L300-0123.000.120.0388 x 75 x 61mm
L300-0153.000.150.0388 x 75 x 61mm
L300-0183.000.180.0388 x 75 x 61mm
L300-0223.000.220.0488 x 75 x 61mm
L300-0273.000.270.0488 x 75 x 61mm
L300-0333.000.330.0588 x 75 x 61mm
L300-0393.000.390.0588 x 75 x 61mm
L300-0473.000.470.0688 x 75 x 61mm
L300-0563.000.560.06105 x 92 x81mm
L300-0683.000.680.07105 x 92 x81mm
L300-0823.000.820.08105 x 92 x81mm
L300-1003.001.00.09105 x 92 x81mm
L300-1203.001.20.10105 x 92 x81mm
L300-1503.001.50.12105 x 92 x 81mm
L300-1803.001.80.13107 x 97 x 83mm
L300-2003.002.00.14107 x 97 x 83mm
L300-2203.002.20.15107 x 97 x 83mm
L300-2703.002.70.17107 x 97 x 83mm
L300-3003.003.00.18107 x 97 x 83mm
L300-3303.003.30.19107 x 97 x 83mm
L300-3903.003.90.20151 x 120 x 106mm
L300-4703.004.70.22151 x 120 x 106mm
L300-5603.005.60.25151 x 120 x 106mm
L300-6803.006.80.28151 x 120 x 106mm
L300-8203.008.20.32151 x 120 x 106mm
L300-10003.0010.00.38162 x 136 x 138mm
L300-12003.0012.00.46162 x 136 x 138mm
L300-15003.0015.00.46162 x 136 x 138mm
Colissimo - TNT - SoColissimo
