MUNDORF BH71 Copper Wire Ferrite Core Self 0.71mm 8.2mH
Self à Ferrite MUNDORF BH71 Fil Verni 0.71mm 8.2 mH
The BH series combines outstanding electrical and mechanical properties that make it an excellent choice for filtering high power woofers or for any other application requiring high inductance and/or low resistance in a small volume.
Reference : 4518
16,60 €tax incl.
13,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
Mundorf BH71
Varnished Wire Ferrite Core Self 0.71mm 8.2mH
Mundorf BH71 Self à ferrite fil verni
In the pure Mundorf tradition, the BH71 ferrite chokes make use of the best materials and rise to the quality standards that have made the reputation of this famous German firm.
Built around a high capacity HP3616 ferrite core, the BH71 chokes are wound with 99.99% pure OFC copper wire and benefit from the "varnished coil" technique dear to the manufacturer. The coils have tinned ends and are marked with the values. The inductance is measured at 25°C. The tolerance is ±3%.
Mundorf varnished coils
When an electric current passes through a coil, it inevitably causes the different windings of the coil to vibrate. The induced microphonic effect (or the conversion of a mechanical movement into electrical oscillations) adds these oscillations to the original musical signal, altering its precision and integrity. Concretely, the reproduction loses transparency, its spatialization is affected and distortions are significantly increased. This physical phenomenon and its perverse effects on the signal are almost eliminated thanks to the "varnished coil" technique developed by Mundorf.
The varnished coils are made from a special wire. An additional layer of varnish on the outside of the wire is quickly melted by the passage of a strong electrical pulse. This process ensures that the coils are firmly connected to each other and can no longer emit unwanted vibrations.
Product typeFerrite self
Inductance8.2mH
Tolerance±3%
RDC0.8Ω
Dimensions35 x 25mm
Inductance (mh)8.2
The BH series combines outstanding electrical and mechanical properties that make it an excellent choice for filtering high power woofers or for...
