MUNDORF N300 Zero Ohm Self Coil 1.5mH
Self Mundorf Zero Ohm Coil N300 1.5mH
The Zero Ohm Coil (ZOC) is a transformer sized coil. It is made of Feron, a high quality material that limits the induced distortion to a maximum. In the ZOC, the center space is calibrated and adjusted by hand between the two laminar cores.
Reference : 1695
165,00 €tax incl.
137,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Mundorf N300
Self Zero Ohm Coil 1.5mH
Mundorf N300 Self Bobine Zéro Ohm
The Zero Ohm Coil (ZOC) is a transformer sized coil. It is made of Feron, a high quality material that limits the induced distortion to a maximum. In the ZOC, the center space is calibrated and adjusted by hand between the two laminar cores (one L-shaped, one E-shaped). The volume of the center gap determines the inductance of the coil and requires great care in the manufacturing process. It must not be too thin, otherwise saturation effects could occur at high load. These coils are recommended for filtering bass speakers. Their low impedance allows to improve the impulse response (better speaker behaviour).
Product typeZero Ohm Coil
ToleranceMax. 5%
CoreFeron
Conductor materialOFC Copper (purity : 99.99%)
Inductance1.5mH
Dimensions106 x 94 x 88mm
Inductance (mh)1.5
The Zero Ohm Coil (ZOC) is a transformer sized coil. It is made of Feron, a high quality material that limits the induced distortion to a maximum....
