MUNDORF N300 Zero Ohm Self Coil 1.8mH
Self Mundorf Zéro Ohm N300 1.8mH
he Zero Ohm Coil (ZOC) is a transformer format coil. It is made of FERON, a high quality material that limits distortion to a minimum.
Reference : 1697
169,00 €tax incl.
140,83 € tax excl.
Shipping date: 18-04-2024.
Shipping from France
Billing in France
Technical support in France
Mundorf Zero Ohm
Self N300 1.8mH
Mundorf Zero Ohm Self N300 1.8mH
The Zero Ohm Coil (ZOC) is a transformer format coil. It is made of FERON, a high quality material that limits distortion to a minimum. In the ZOC the central space is calibrated and adjusted by hand between the 2 laminar cores (one I-shaped and one E-shaped). The volume of the central space determines the inductance of the coil and requires great care in the manufacturing process. It must not be too small, otherwise saturation effects could occur at high load.
These coils are recommended for filtering bass speakers. Their low impedance improves impulse response (loudspeaker better held)
Product typeZero Ohm Self
Tolerance5X Max
CoreFeron
Coil materialOFC Pure Copper 99.99%
Weight0.75kg
Resistance0.02 Ohm
Inductance (mh)1.8
