1877PHONO Ground pole 4mm Gold plated 24k
1877 Phono Borne de masse "Ground pôle" bornier 4mm Plaqué Or 24k
Reference : 5332
12,90 €tax incl.
10,75 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
This simple and uninsulated terminal block can be used to make a ground terminal on a device, or any other connection.
The hole on the outside can be fitted with a banana strip plug (type Viablue TS2).
Specifications:
  • 24k Gold plated terminal block
  • Maximum cable diameter: 2.50mm
  • Thread diameter: 3.80mm
  • Maximum panel thickness: 9.5mm
  • Threaded rod length: 15mm
https://www.audiophonics.fr/images2/5332/5332_1877GROUNPOLE.jpg
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)9.5
Accepts Banana PlugsYes
ConnectorSpeaker terminal
8 reviews
perfectly made and correctly packaged
This review has been posted for 1877PHONO Ground pole 4mm Gold plated 24k
Great project Ground Pole.
I purchased & used this ground pole when fitting RCA jack sockets to a Thorens TD-160 mkII. It is very good quality & super conductive. Will definitely accommodate a substantial ground lead to be fitted to the turntable. Highly recommend for project work. Great service as usual through Audiophonics.
Veredlung meiner Verstärker
Ob Phono - Pre oder Vollverstärker:
Erste Wahl!
First class!
Premier choix!
Borne de masse
Très bon produit conforme à la description.
Très satisfait
excellent produit pour rénover une platine vintage Audiotec.
