DAYTON AUDIO BPA-38G HD Gold Plated Binding Post Ø15mm x 57mm (Pair)
The Dayton Audio BPA-38G HD terminal blocks have been designed to help ensure proper signal reproduction. Thus, the contact material is 24K gold plated, ensuring both very good conductivity and excellent oxidation resistance.
Reference : 12765
11,90 €tax incl.
9,92 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
Gold Plated Binding Post ⌀15mm x 57mm (Pair)
Dayton Audio BPA-38G HD Borniers plaqués or
In addition, these terminals can accommodate cables up to 3.26mm in diameter (8AWG) or banana plugs for an easier connection. The large diameter notched head allows easy grip for improved ergonomics.
The long screw pitch of the terminal block allows integration on panels up to 25.4mm thick. In addition, the notched part inside will prevent the connector from rotating on itself.
PlatingGold 24k
Max panel thickness25.4mm
Cutout diameter6.35mm
Accepts banana plugsYes
Total length57mm
Max diameter15mm
Connection typeTo solder
ColorGold
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)6.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
6 reviews
Borniers Dayton BPA 38 hg
J'ai deja utilisé ces borniers , je les trouve de bonne qualité et bon serrage.
This review has been posted for DAYTON AUDIO BPA-38G HD Gold Plated Binding Post Ø15mm x 57mm (Pair)
Bor
Très bon serrage ,bonne qualité je les ai utilisés plusieurs fois.
Excellent quality.
Tige longue
Borniers avec tige longue, parfait pour les parois épaisses (dans mon cas, DIY en contreplaqué de 22mm)
Qualité
La qualité est là, ces bornes sont belles et pratiques, bien que j'aurais aimé avoir un écrou de serrage 6 pans à la place de moleté, pour un serrage à la clé.
The Dayton Audio BPA-38G HD terminal blocks have been designed to help ensure proper signal reproduction. Thus, the contact material is 24K gold...
