Transparent plastic loudspeaker terminal block with integral contacts gold plated end 24k .
Accepts large diameter cables via one fully insulated burial system , as well asbanana sheets.
Insulating washer with key. Screw terminal block .
Specifications:
Mounting type | To weld |
Connectic | Female |
Max panel thickness (mm) | 15.5 |
Accepts Banana Plugs | Yes |
Connector | Speaker terminal |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
