WBT-0708Cu Gold Plated Speaker Terminals (Set x4)
WBT-0708Cu Borniers pour haut parleur plaqué Or (paire x2)
Reference : 6409
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 02-04-2024.
Shipping from France
Billing in France
Technical support in France
The Nextgen 0708 Copper comes from the latest development by WBT and is supplied with pure copper conductors and a gold-plated finish.
Thanks to the separation of the transmission line and the mechanical chassis, it is now possible to use high quality materials for each of the elements of this terminal block. Although better electrical conductor, copper or silver have some mechanical limitations that we have bypassed by the use of high performance plastics.
Ofthe more the core of this new terminal block is made in one piece, thus avoiding unnecessary resistance. The signal conductor is protected by a glass fiber matrix reinforced with mineral plastic and covered with a non-magnetic steel body. A complementary elastomer damping system makes it possible to drastically limit the vibrations transmitted to the driver. The microphone effect is thus amply reduced in favor of the precision of the transmitted sound signal.
Thetion of this product makes every effort to ensure the best electrical isolation.
SPECIFICATIONS:
  • Max conductor cross section: Internal: 4mm² (11 AWG) / External: 4mm² (11 AWG)
  • External connection: Banana 4mm, forks 6 or 8mm, bare wire crimped.
  • Internal connection: Weld or 6.3mm plug-in connector.
  • Mounting wall thickness (wall): From 0.9 to 6.5mm with Puzzle plates and 4.5mm to 6.5mm without plates
  • Identification: 2 Red, 2 White
  • Pure copper plated OR
https://www.audiophonics.fr/images2/6409/6409_WBT0708.jpg
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)6.5
Accepts Banana PlugsYes
ConnectorSpeaker terminal
très très bien
Pour upgrader des JBL, en comparaison avec l'original puis d'autres borniers 8mm en ofc plaqué argent, les borniers WBT sont très très bien, pas d'effet bouchon ou de voile sur une partie du spectre qui est étendu, ça descend vraiment bas et monte bien haut , la quantité de matière utilisé est cohérent avec les sections de câble HP généralement utilisé.
Très content de ce produit, vraiment.
Merci à Audiophonics pour la passion commune, bravo à l'équipe.
This review has been posted for WBT-0708Cu Gold Plated Speaker Terminals (Set x4)
