WBT-0703Cu Speaker Terminals Gold Plated Copper (Set x4)
WBT-0703Cu Borniers pour haut parleur plaqué Or (Set x4)
The result of the latest generation of development by WBT, the 0703Cu speaker terminals feature pure copper conductors and a gold-plated plating. Thanks to the separation of the transmission line from the mechanical chassis, it is now possible to use high-quality materials for each component of these terminal blocks. Although the best electrical conductor, copper or silver do have some mechanical limitations, which WBT has overcome by using high-performance plastics.
4.7 / 5
Reference : 6408
159,00 €tax incl.
132,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
WBT-0703Cu Speaker terminals
What's more, the core of this new terminal block is made of a single piece, thus avoiding any unnecessary resistance. The signal conductor is protected by a fiberglass matrix reinforced with mineral plastic, and covered by a non-magnetic steel body. A complementary elastomer damping system drastically limits the vibrations transmitted to the conductor. The microphonic effect is thus greatly reduced, to the benefit of the precision of the sound signal transmitted.
Product typeSpeaker terminals
Contact materialCopper
Contact platingGold
CompatibilityBanana 4mm
Spade  6 / 8mm
Bare wire
Max cable conductor section4mm² (11AWG)
Internal connectionSolder lug or 6.3mm flat lug
Max panel thickness10mm
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)10.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
3 reviews
Yes! Just great.
Great Product. This low mass principle works. Gives a wide, neutral well balanced/homogenous sound. Very well built, carefull sensitiv, as not too much material. Hard to make better. You get the best of this conducter material. Absolut bang for the buck. Yes, in practice would be nice to have a wider contact area for spades, but would it sound better? Max.
This review has been posted for WBT-0703Cu Speaker Terminals Gold Plated Copper (Set x4)
Bornier de qualité mais néanmoins un peu cher
Borniers de qualité avec contacts plaqués or, acceptent les cosses de connexion sans problème. Néanmoins on peut se demander si leur prix est justifié compte-tenu de la fabrication en plastique. Attention à assurer un écartement suffisant lors du perçage du châssis car leur diamètre extérieur est important, plus que des borniers plus classiques.
Borniers WBT-0703Cu
Toujours aussi satisfait de ces borniers qui équipent à présent toutes mes boites amplis .Merci par la rapidité de votre livraison. A bientôt.Amical bonjour.
The result of the latest generation of development by WBT, the 0703Cu speaker terminals feature pure copper conductors and a gold-plated plating....
