WBT-0708 Terminal blocks for pure silver speaker (set x4)
Coming from the latest generation of development by WBT, the Nextgen 0708 AG is fitted with Pure Silver conductors.
Thanks to the separation of the transmission line and the mechanical chassis, it is now possible to use superior quality materials for each of the elements of this terminal block. Although it is a better electrical conductor, copper or silver have some mechanical limitations which we have overcome by the use of high performance plastics.
In addition, the soul of this new terminal block consists of a single piece, thus avoiding any unnecessary resistance. The signal conductor is protected by a glass fiber matrix reinforced with mineral plastic and covered by a non-magnetic steel body. An additional elastomer damping system drastically limits the vibrations transmitted to the driver. The microphone effect is thus greatly reduced in favor of the precision of the transmitted sound signal.
The design of this product makes every effort to ensure the best electrical isolation.
SPECIFICATIONS :
Max conductor cross-section : Inner : 4mm² (11 AWG) / Outer: 4mm² (11 AWG)
External connection : Banana plugs 4mm, spades6 ou 8mm, bare wire.
Internal connection : Weld or 6.3 flat connector.
Panel mounting thickness : From 0.9 to 6.5mm with Puzzle plates and 4.5mm to 6.5mm without plates
Identification : 2 x red, 2 x white
Pure Silver
