JANTZEN AUDIO C-COIL 000-6485 4N Copper 14AWG Ø1.6mm 10mH 0.11 Ohm
Jantzen Audio C-Coil 10.0mH 1.4 mm - Bobine torique Cuivre
Reference : 10352
61,90 €tax incl.
51,58 € tax excl.
Shipping date: 24-04-2024.
Shipping from France
Billing in France
Technical support in France
Jantzen Audio toroidal coil / C-Coil
Low filter coil
Jantzen Audio's C-Coil Toroidal Coils have very low electric resistance and excellent heat tolerance. They can thus withstand high power without overheat-induced distorsion. This model can handle up to 1500W (RMS) / 8Ω . Because of this, Jantzen C-Coil make great inductors for passive filtering low-frequencies crossover.
Caution, due to the electromagnetic field inherent to their construction, C-Coils coils are not suitable for a crossover rising above 1.20kHz. Similarly, they are not intended for amplification or other active system.
Each coil is individually tested with the measurement system CLIO @ 1kHz AC 1V.
TypeETP (Electrolytic-Tough-Pitch) C11000 / IACS certified copper
MaterialsCopper ETP Standard C11000 / Certified IACS
CoreEpoxy laminated steel plates
Inductance10,0mH +/-5%
Power Handling (RMS)1500W (RMS) / 8Ω
RDC0.11 Ohm
Coil External Diameter93mm
Coil Height32mm
Coil Internal Diameter34mm +/-3
Wire Diameter1,60mm⌀
AWG14
Weight0,870kg
Inductance (mh)10.0
