RAMM AUDIO AMADEUS 5 MK2 Speaker Cable OCC Copper 6x1.5mm² Ø16mm
RAMM AUDIO AMADEUS 5 MK2 Speaker cable OCC Copper 11AWG Ø16mm
4.8 / 5
Reference : 12202
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
MMAR Amadeus 5 Mk2
ramm-audio-amadeus-5-mk2-cable-hp-cuivre
Designed according to extremely strict specifications, the Amadeus 5 Mk2 cable is dedicated to wiring (& bi-wiring) loudspeakers and to power cables.
This speaker cable / power offers superior performance thanks to the use of materials and manufacturing methods that are rare in this price range.
The conductors are six core pure copper OCC and its insulating structure (Air Geometry Design) uses air with a pattern designed by the mark itself.
Structure%20c%C3%A2ble%20AMADEUS%205%20M
The connectors are arranged so that the wiring of your devices according can be "tuned" according to their strengths and their weaknesses. One can dedicate 2x2 conductors to the positive and 2x1 conductor to the negative to obtain a rich and balanced sound stage in a bi-wiring context. Conversely, less symmetrical arrangements may also be made for filter / crossover.
In addition to the six main strands of 16AWG there is a seventhdriver designed to connect the mass and thus avoid most noise.
Definitely audiophile, Amadeus cable 5 Mk2 offers pure performance through high quality multiple conductors and a protective screen shield Aluminum / PP / PVC.
All conditions are met for optimal resistance to interference with minimal distortion.
Bi-wiring amplifier
Amadeus 5 wiring diagram
Wiring for AC outlet
Amadeus 5 wiring diagram sector
TypeCable sold by the meter
ConductorsPure copper OCC 11AWG (4.17mm²)
Cores6 cores made from 6x7 conductors
InsulatingDesigned by Ramm / air geometrical structure and polypropylene
Diameter per conductorApprox. 2mm
Total Diamtètre16mm
Common useSpeaker câble / Double speaker cables / power cable
PVC bodyBraided Nylon & PVC Body Blue
Diameter (mm)16.0
Length (m)Sold by length
Number of conductors6
Insulation materialPE
ShieldingYes
Section (mm²)1.5
Ground / ShieldingYes
31 reviews
Excellent
Avec ce câble, j’ai à la fois réalisé des cables d’enceintes et des cables secteur. Le résultat est à la hauteur de ce que j’attendais. J’ai essayé sur plusieurs types d’enceintes. Ce câble amène plus de douceur, de neutralité, de définition et à la fois plus de dynamisme.
Soyez bien équipé des bons outils. La pince à dénuder est obligatoire, Une petite pince qui serre, mais sans couper vous permettra de dénuder les petites gaines PE.
Si vous voulez relier votre câble à la carcasse de votre ampli, il faudra couper une première fois et recouper une seconde fois les cables de manière à ce que le fil de drain soit plus long.
Je note cinq étoiles ce câble, mais je note uniquement 2 étoiles le service commercial, qui n’a pas été à l’écoute de ma demande. Ils m’ont automatiquement orienté vers des cables d’une autre marque (Mogami, elecaudio) Qui soi-disant ont un meilleur rapport qualité prix. Je connais ces cables et il n’arrivent pas au niveau des ramm audio. À croire que les commerciaux de Audiophonics se basent uniquement sur les avis et le nombre de ventes… D’autre part, même pour une commande de 1000 € pour 14 m de câble, ils sont inflexibles sur les prix. Dommage que la démarche commerciale ne soit pas de la partie.
This review has been posted for RAMM AUDIO AMADEUS 5 MK2 Speaker Cable OCC Copper 6x1.5mm² Ø16mm
How is this possible!
Bought this cable to try out because of a YouTube channel recommended it and to finally find a good speaker cable for my Duntechs (Dynaudio drivers). Mismatch in the past, or hardly any difference between different cables. I had the cable laying around for year and last month i stripped it and hooked it up bare wire.
Initally it worked just fine. No difference with my solid core DMN's. But now approx 100hrs in and something has changed. I listen to rock a lot. And those recordings are mostly unlistenable. But suddenly it sounds so full and PRAT was :) The emotion in the song :) My phantom centre channel is much more vivid. With much clearer boundries of imaging. Subjectively i feel it just is starting to be played in. So i hope in the next 2 months it will sound even better. Occ is the real deal ladies and gentleman. Hop in, the audio water great, why pay more.
Mieux
Après avoir dénudé les 4 ou 3 fils sur 7 ca chante d'un grand naturel par contre il n'a pas de profondeur
j'ai branché le cable nu aux borniers avec les bonnes bananes sont devrait arriver a quelque chose de bon voir très bon
deception
Cable utilise en mono cablage
l'image est retrecis il est brouillion
bonne attaque du medium a par ca bref une *
 (3)
 (3)
Très très bon câble H.P
Sur ma config;
Ampli tube CAYIN KT88 sur des KLIPSCH RF7 MKII.
J'ai pris ce câble sur 2X4 mètres, que j'ai monté comme décrit dans présentation du produit,
J'y ai aussi monté des Jumpers avec des fourches Red Copper avec le câble NEOTECH NEMOS-3080 : (soit 3 X 0.63 mm rouge "+") et 3 X 0.63 mm noir "-" ) , ce qui donne des jumper de 1.89 mm. plus le RAMM 1.5 mm au dessus
les connecteurs :
4 X RAMM AUDIO 50400-GT Fourches Red Copper sortie Ampli et
4 X VIBORG VB401 Fiches Banane Cuivre Pur Red Copper entrées H.P.
Le résultat est magnifique !
Les RF7 Jouent comme jamais. Aucune brillance sur les hautes fréquences, ce qui serait l'unique défaut des KLIPSCH RF7MKII avec d'autres câbles .
Par contre C'est très bon ! Tout est là ! Ca joue très très large, avec un superbe relief … un grave profond, lourd et bien tenu sur toute sa gamme de fréquences et une définition du message sonore vraiment Majestueux et Somptueux
C'est beau !
Avec ce câble on révèle enfin tout le potentiel de ces belles Américaines .
J'obtiens ce même résultat avec les amplis PARASOUNT
En espérant avoir pu vous aider dans votre recherche
je vous souhaite d'excellentes écoutes
 (5)
