ELECAUDIO CS-321B Power Cable OCC PTFE 3x2.5mm² Double shielding Ø12mm
ELECAUDIO CS-321B OCC Power Cable OCC FEP 3x2.5mm² Ø 12mm
4.6 / 5
Reference : 5258
14,90 €tax incl.
12,42 € tax excl.
Shipping date: 24-04-2024.
Shipping from France
Billing in France
Technical support in France
Thanks to its expertise in the production of customized audio / video cables, the ELECAUDIO team has devised a mains cable capable of satisfying your needs and desires at an affordable price, while guaranteeing the expected results thanks to the latest materials and technologies.
The Phase and Neutral (Black and White) of the CS-321B are each made up of:6 DECO deoxygenated copper strands of 0.10mm diameter, more 1 strand OCCof 0.12mm in diameter, or one section of 2.5mm² per conductor .
Is the Earth (green) composed of 6 DECO deoxygenated copper strands of 0.10mm in diameter, plus OFC of 0.12mm diameter. Sor a section of 2.5mm² for this driver as well.
ELECAUDIO CS-321B OCC Câble Secteur OCC FEP 3x2.5mm² Ø 12mm
These 3 conductors with a very sharp structure are encapsulated individuallyin PVC + FEP jackets marked with a color code :Black / White / Green. The three beams thus formed are themselves isolated from each other and kept in a distant order by means of a padding in cotton which provides flexibility and firmness to the cable.
A double insulation made of FEP insulation and a PVC sheath, concludes this cable and finishes making the CS-321B particularly resistant to the harshness of the outside world while giving it a unique design thanks to its night blue color which brings a touch of class and sobriety.
Features:
  • Phase and Neutral Conductors (Black and White): 1x26x0.12mmOCC+ 6x38x0.10 OFC,section of 2.5mm² each
  • Ground conductor (green): 1x26x0.12mmOFC+ 6x38x0.10 OFC,section of 2.5mm² also
  • Paddingcotton
  • armouringMylar
  • Shielding Drain: 26 x 0.16mm
  • Shielding braid:OFC Copper
  • Double insulation: Insulation winding PTFE+ sheathPVC
  • Total cable diameter: 12 mm
  • Bending radius: ~ 6cm
  • Color: dark blue
Diameter (mm)12.0
Length (m)Sold by length
Number of conductors3
Insulation materialPTFE
ShieldingYes
Section (mm²)2.5
ConnectorN/A
Ground / ShieldingYes
27 reviews
Good performances
I tried Elecaudio CS 321B on my CD reader and the result was definitely better than the CS 331B I used till now. So I decided to try it also on my ampli.
Audiophonics service is precise and on time as usual
This review has been posted for ELECAUDIO CS-321B Power Cable OCC PTFE 3x2.5mm² Double shielding Ø12mm
Câble elec audio
Super produit a pas cher pour ma barrette, en association avec les prises furutech. Le câble est très bon en son si il y a des prises de qualité,, comme pour tout câble de toute façon.
Compared this cable with the stock cable that goes with Marantz PM-8006 and instantly heard tighter bass. No soldering. Connectors are also Elecaudio.
Iscott
Câble très bien construit et il agit sur la musicalité et la différence est audible de suite par rapport aux autres câbles mais la restitution est très douce et feutrée manque de dynamique a marier avec des électroniques agressives .
Cordialement
Elecaudio CS-321B
Voilà un câble extrêmement qualitatif d’une conception et d’une réalisation absolument irréprochable, combiné à une Schuko et une IEC du même fabricant vous pouvez vous assembler un câble secteur littéralement à tomber à la renverse pour le tarif des modèles de base des grands manufacturiers, soit moins d’une centaine d’euros.
Au moment de l’écoute,...c’est la deuxième claque, le son gagne en punch mais aussi en finesse et fourmille de détails, c’est assez hallucinant !
Le tuto d’Audiophonics est très bien fait pour ce qui est de l’assemblage dudit câble et permet d’éviter les erreurs classiques des premiers montages du type raccordement du drain oublié ou bien branchement pas en phase... La phase et le neutre étaient d’ailleurs inversés sur la schuko, attention !
Résultat vraiment remarquable compte tenu encore une fois du coût de revient totalement dérisoire.
