ELECAUDIO CS-321B Power Cable OCC FEP 3x2.5mm² Double shielding Ø 12mm
ELECAUDIO CS-321B OCC Power Cable OCC FEP 3x2.5mm² Ø 12mm
4.3 / 5
Reference : 5258
19,90 €tax incl.
16,58 € tax excl.
Available
Shipping date: 25-06-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Thanks to its expertise in the production of customized audio / video cables, the ELECAUDIO team has devised a mains cable capable of satisfying your needs and desires at an affordable price, while guaranteeing the expected results thanks to the latest materials and technologies.
The Phase and Neutral (Black and White) of the CS-321B are each made up of:6 DECO deoxygenated copper strands of 0.10mm diameter, more 1 strand OCCof 0.12mm in diameter, or one section of 2.5mm² per conductor .
Is the Earth (green) composed of 6 DECO deoxygenated copper strands of 0.10mm in diameter, plus OFC of 0.12mm diameter e. Sor a section of 2.5mm² for this driver as well.
ELECAUDIO CS-321B OCC Câble Secteur OCC FEP 3x2.5mm² Ø 12mm
These 3 conductors with a very sharp structure are encapsulated individuallyin PVC + FEP jackets marked with a color code :Black / White / Green . The three beams thus formed are themselves isolated from each other and kept in a distant order by means of a padding in cotton which provides flexibility and firmness to the cable.
Adouble insulation made of FEP insulation and a PVC sheath, concludes this cable and finishes making the CS-321B particularly resistant to the harshness of the outside world while giving it a unique design thanks to its night blue color which brings a touch of class and sobriety.
Features:/ Strong>
  • Phase and Neutral Conductors (Black and White): 1x26x0.12mmOCC+ 6x38x0.10 OFC,section of 2.5mm² each
  • Ground conductor (green): 1x26x0.12mmOFC+ 6x38x0.10 OFC,section of 2.5mm² also
  • Paddingcotton
  • armouringMylar
  • Shielding Drain: 26 x 0.16mm
  • Shielding braid:OFC Copper
  • Double insulation: Insulation windingEFF+ sheathPVC
  • Total cable diameter: 12 mm
  • Bending radius: ~ 8cm
  • Color: dark blue
Diameter12.00
Numéro de Conducteur3
Matériaux IsolationFEP
BlindageOui
Section2.5
Colissimo - TNT - SoColissimo
12 reviews
CS 321 B
Si vous avez des problèmes avec le haut du spectre dominant ou agressif, c'est la solution avec des fiches Furutech Cuivre plaqué Or. Egalement le médium s'en trouve plus "plein" et le bas su spectre plus chaud, plus profond et détouré; Attention 2 à 3 heure de rodage pour s'ouvrir.
James
This review has been posted for ELECAUDIO CS-321B Power Cable OCC FEP 3x2.5mm² Double shielding Ø 12mm
Good quality
Good construcción,well insulated, and general good wire in its price.
Audiophonics sould sell all the bulk cables in Units half a meter
Très typé
Câble à la restitution très douce, feutrée et descendante, avec un sérieux manque d'ouverture, de dynamique et d'expressivité. Musicalité très typée avec un rendu "romantique" mais pas naturel, où Horowitz semble avoir laissé la clavier à Clayderman, où Liane Foly semble avoir fumé plusieurs pétards, où Bach a été sauvagement remplacé par Claude Bolling. Dommage, car la qualité de fabrication est exemplaire. A marier avec des électronique trop analytiques ou trop froides.
excellentisime
cacle secteur excellente qualité facile à monter et son riche et détaillé tres agréable tres doux ce qui évite les fatiques auditives par rapport au yarboo qui se trouvent à la longue quelque peu agréssif,et surtout moin galer à monter,bravo vraiment 5 étoiles!!!
tres bien construit
très bon câble, longueur de 2 mètres utilisé entre la prise murale et un boitier audiophonics multiprise, ensemble Stax avec ampli à lampes T+A dac 8, câble équilibré transparent, pas d'agressivité et pas du tout coloré, vu la technologie qui est utilisée sur ce câble , très bon rapport qualité prix, pas encore complètement rodé, mais la 1 er impression est positive et convainquant, merci à audiophonics
