I tried Elecaudio CS 321B on my CD reader and the result was definitely better than the CS 331B I used till now. So I decided to try it also on my ampli.
Audiophonics service is precise and on time as usual
Thanks to its expertise in the production of customized audio / video cables, the ELECAUDIO team has devised a mains cable capable of satisfying your needs and desires at an affordable price, while guaranteeing the expected results thanks to the latest materials and technologies.
The Phase and Neutral (Black and White) of the CS-321B are each made up of:6 DECO deoxygenated copper strands of 0.10mm diameter, more 1 strand OCCof 0.12mm in diameter, or one section of 2.5mm² per conductor .
Is the Earth (green) composed of 6 DECO deoxygenated copper strands of 0.10mm in diameter, plus OFC of 0.12mm diameter. Sor a section of 2.5mm² for this driver as well.
These 3 conductors with a very sharp structure are encapsulated individuallyin PVC + FEP jackets marked with a color code :Black / White / Green. The three beams thus formed are themselves isolated from each other and kept in a distant order by means of a padding in cotton which provides flexibility and firmness to the cable.
A double insulation made of FEP insulation and a PVC sheath, concludes this cable and finishes making the CS-321B particularly resistant to the harshness of the outside world while giving it a unique design thanks to its night blue color which brings a touch of class and sobriety.
Features:
Diameter (mm) | 12.0 |
Length (m) | Sold by length |
Number of conductors | 3 |
Insulation material | PTFE |
Shielding | Yes |
Section (mm²) | 2.5 |
Connector | N/A |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Ground / Shielding | Yes |
Average votes 4.6 / 5 27 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Gianluigi C.
Jerome t.
Roman R.
Roland B.
Cédric N.
