Bon rapport qualité prix. Je rejoins les divers commentaires.
Bien mieux sur les sources . Branché sur le Dac audio gd r1 un trés joli mariage : Musical et détaillé.
Attention aux codes couleurs. Jaune pour neutre .
By buying this product you get 30 loyalty points
The FP-3TS20 is a very high-performance 3-wire power cable dedicated to uncompromising audio applications. The FP-3TS20 demonstrates manufacturing quality and technicality that leaves no doubt as to its top-of-the-range positioning.
Thus, each conductor is made up of a central core consisting of 56 single crystalline OCC copper strands, each 0.18mm in diameter, surrounded at its periphery by 29 strands of the same composition, i. e. a total cross-section of 2.16mm² per conductor.
Each of these bundles is individually insulated within a 3.53mm diameter polyethylene sheath covered with a teflon film, while the whole is then protected by a double protection with PVC inner sheath and braided copper shielding.
As is customary with this manufacturer, all metals will have benefited from the proprietary Alpha? anti-magnetism process, which involves 2 steps:
1- Cryogenisation of metals by -250°C using liquid nitrogen in order to consolidate their molecular structure and significantly improve their conductivity.
2- Submission of these same metals to a powerful magnetic field created by means of magnets arranged in rings, and whose attraction force is constantly controlled in order to leave no magnetic residue at the end of the treatment.
This second technique, developed in collaboration with the Japanese firm SEKIGUCHI MACHINE SALES, takes part in making FURUTECH cables exceptional conveyors for any electrical signal invested in sound reproduction.
Specifications:
Diameter (mm) | 14.3 |
Length (m) | Sold by length |
Number of conductors | 3 |
Insulation material | Other |
Shielding | Yes |
Section (mm²) | 2.16 |
Connector | N/A |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Ground / Shielding | Yes |
Average votes 4.6 / 5 13 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Denis L.
Francisco Jose P.
Alain V.
Sylvain D.
