FURUTECH FP-TCS31 Power cable Alpha High purity OFC Shielded 3x2.5mm² Ø16mm
FURUTECH FP-TCS31 Power cable Alpha High purity OFC Shielded 3x2.5mm² Ø 12mm
By buying this product you get 51 loyalty points
Reference : 9873
175,00 €tax incl.
145,83 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Resolutely high-end of the famous brand, this elitist sector cable represents the culmination of a great know-how.
Like all their products, each conductor undergoes an Alpha cryogenic treatment in order to optimize its conductivity:
1- Cryogenization of metals by -250 ° C using liquid nitrogen in order to consolidate their molecular structure and significantly improve their conductivity.
2- Submission of these same metals to a powerful magnetic field created by means of magnets arranged in rings and whose attraction force is constantly controlled in order to leave no residual magnetic at the end of the treatment.
This drytechnical wave, developed in collaboration with the Japanese firm SEKIGUCHI MACHINE SALES, participates in making cables FURUTECH of the conveyors of exceptions for any electric signal invested in the sound reproduction.
TypeHigh Performance Conductor.
ConductorsCopper α (Alpha) OFC High purity (99.996%).
Conductors diameter3 x 2.5mm⌀
InsulationSoft PVC insulation of 5mm diameter.
External envelopegreen PVC High resistance.
Shielding0.12mm braided OFC copper strands.
Tensile strength250 MPa.
Conductivity index101.5% IACS.
Elasticity of conductors35%.
Total cable diameter16mm
Diameter (mm)16.0
Length (m)Sold by length
Number of conductors3
Insulation materialPVC
ShieldingYes
Section (mm²)2.5
ConnectorN/A
Ground / ShieldingYes
16 reviews
Équilibre et performance
Ce câble est très équilibré et ne zoom pas le haut du spectre « ouf » Aucunes fatigue!
Il à même gommé une très légère acidité sur certains aigus qui était de trop dans la musique de qualité moyenne.
La force de ce câble est le médium qui est chaleureux et bien présent sur les voix.
je ne trouve pas une grande différence sur les graves profond .
Le changement globale de sonorité entre les câble secteur et très discuté mais oui il y a une équilibre différent à l’écoute mais Il faut une électronique derrière et des enceintes qui peuvent vous donner cette chance de le percevoir, est ce n’est pas à 20% de volume qu’il y aura une différence mais plutôt dans les écoutes assez soutenue ou les défauts et qualité sont mis en évidence d’un système.
Je conseil ce câble pour écoute neutre et agréable sans faire de fausse notes.
Merci
This review has been posted for FURUTECH FP-TCS31 Power cable Alpha High purity OFC Shielded 3x2.5mm² Ø16mm
Un vrai câble premium
Une amélioration au niveau de la scène sonore, les timbres me paraissent très justes, je suis satisfait de mon achat.
Jubilatoire
Câble monté sur un dac R7 avec des Furutech FI-E48 et une FI-12 en IEC pcq peu de place à l'arrière. Mon dac s'est réveillé, il chante déjà à merveille alors que le câble n'est pas encore rodé. Câble de qualité qui mérite de bonnes prises pour du bon matos, et bien respecter la phase secteur évidemment.
Very good cable
This cable I compared with S032N, both are rigid and difficult to lay down in a small space. TCS31 is good in bass, medium bas and has sweet mid tones, high tones are a bit behind. S032N is good in bas but worster than TCS31 especially in medium bas, are less sweet, more pushed in medium tones, but are much more detailed in high tones. TCS is more comprehensive, little more sweet and heavier, S032N is more fresh.
 (6)
un rendu magnifique
Excellent câble, meilleur investissement que j'ai fait, j'aurai du commencer par le début...ce câble est aéré,défini, doux, chaleureux et mon ampli descend beaucoup plus bas sans être baveux ni imprécis...
c'est assez surprenant même quant au rodage supposé (le son était vraiment mauvais au début) d'un câble, celui-ci serait très long, plusieurs dizaines d'heures, je dirai une bonne centaine.La bosse dans le haut-médium finit par s'estomper.Ce câble est juste ultra musical, pas donné certes mais donnent de vrais résultats contrairement à beaucoup d'autres câbles.Bluffant.Et il n'engendre aucune dureté, ni fatigue auditive.Il apporte un léger coté "tube" aux transistors.Le médium est magnifique, l'aigu soyeux.Je ne pensais pas qu'un câble secteur pouvait apporter tant.
J'en ai pris un second pour mes sources et ça marche du tonnerre.Je recommande vraiment.
 (3)
