NCF BOOSTER SHAFT BAR ADJUSTER Precision Height Adjuster for NCF Booster Cable Support
NCF Furutech Booster Shaft Bar Adjuster are optional parts that can be combined with NCF Booster and NCF Booster Signal. This accessory allows precise height adjustment of NCF Booster cable supports up to +7mm for optimum connector retention.
Reference : 13278
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 24-04-2024.
Shipping from France
Billing in France
Technical support in France
Furutech NCF Booster Shaft Bar Adjuster
Ajusteur de hauteur précis pour NCF Booster
NCF Furutech Booster Shaft Bar Adjuster are optional parts that can be associated with NCF Booster and NCF Booster Signal. This accessory allows precise adjustment of the height of the NCF Booster cable supports up to +7mm, allowing you to find the optimal setting for holding your connectors. The rubber cones in these Shaft Bar Adjusters incorporate Furutech’s NCF technology, eliminating vibration through efficient damping and eliminating static charge for better restitution.
Explicative video (EN)
MaterialNCF Nylon Resin
Ni plated Brass screw
Total dimensions42.6 x 22mm
Weight (2 adjusters)57g
Quantity2 unit
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorN/A
Conductors material (Cable)N/A
Kris Cauwelier
Je suis très content du produit que vous m'avez envoyé et du service et de vos informations. Et j'achéterai encore de vos produits dans un future proche. Merci beaucoup.
This review has been posted for NCF BOOSTER SHAFT BAR ADJUSTER Precision Height Adjuster for NCF Booster Cable Support
NCF Furutech Booster Shaft Bar Adjuster are optional parts that can be combined with NCF Booster and NCF Booster Signal. This accessory allows...
