FURUTECH DPS 4.1 Power Cable Copper OCC DUCC Alpha Treatment 4.02mm² Ø17mm
FURUTECH DPS 4.1 Câble secteur
This Furutech DPS4.1 power cable is designed with a 79 / 0.18α-OCC conductor, a 37 / 0.18α-DUCC conductor as well as a 42 / 0.18α-DUCC conductor. DUCC (Ultra Crystallized High Purity Copper) conductors are supplied and tested by Mitsubishi Materials Industries (the world's leading manufacturer of highest purity oxygen-free copper).
By buying this product you get 162 loyalty points
Reference : 15068
549,00 €tax incl.
457,50 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
Câble vendu au mètre
FURUTECH DPS 4.1
This Furutech DPS4.1 power cable is designed with a 79 / 0.18α-OCC conductor, a 37 / 0.18α-DUCC conductor as well as a 42 / 0.18α-DUCC conductor. DUCC (Ultra Crystallized High Purity Copper) conductors are supplied and tested by Mitsubishi Materials Industries (the world's leading manufacturer of highest purity oxygen-free copper). This extremely pure material is processed with a technology meant to optimize crystal alignment while reducing crystal grain juxtapositions, resulting in an extremely efficient conductor.
The OCC conductors are the result of a further treatment with the Alpha Super Cryogenic and Demagnetizing treatment. They benefit from a straight alignment where its more massive "fibrous" crystals have an increased length in order to create the fewest crystalline junctions possible. The entire cable is insulated with an internal Fluoropolymer layer and an external polyethylene layer. Finally, a copper foil shielding with braided OFC copper makes it possible to reject interference and preserve the audio qualities of your devices as much as possible.
TypePower cable
Number of conductorsx3
Conductors79/0.18α-OCC
37/0.18α-DUCC
42/0.18α-DUCC
InsulatorFEP
P.E.
SheatPVC
ShieldingCopper Foil, OFC braided, Paper
Diameter overall17.0mm
QuantityBy meter
Diameter (mm)17.0
Length (m)Sold by length
Number of conductors3
Insulation materialPE
Insulation materialFEP
ShieldingYes
Section (mm²)4.00
Section (mm²)4.00
ConnectorN/A
Ground / ShieldingYes
6 reviews
Super câble mais….
Je vous avouerais que en recevant mon colis avec le câble et des prises NCF je flippais grave car là ça commençait à chiffrer. J’ai eu l’expérience du tcs31 qui n’a pas été convaincant . Aussi, après avoir monté le tout minutieusement, je le branche sur mon Dac rien ne ne se produit…Je commençais à changer de couleur. J’essaie avec mon préamplificateur Yamaha c5000 : moins bien que le Thunder d’Audioquest. Ma dernière cartouche etait mon conditionneeur secteur qui avait un câble Gigawatt de base. Et alors là, c’était le grand spectacle. Hyper detaillé très beaux timbres un grave propre espace sonore très large (on repousse les murs) . En résumé génial mais avec un conditionneur secteur ou une barrette point final.
This review has been posted for FURUTECH DPS 4.1 Power Cable Copper OCC DUCC Alpha Treatment 4.02mm² Ø17mm
L'excellence
Je suis passé de l'alpha 3 a fp s55n et maintenant le dps en gardant toujours Les mêmes fiches. Le meilleur rapport qualité prix est le s55n qui est génial ,avec le dps on rentre dans le monde du détail de la perfection c'est Un câble pour Les puristes uniquement . + Silence détail envoûtant. - le prix bien sur . Complètement envoûté par le son de ce câble ne surtout pas écouter électro bidouilleur sur youtube c'est une chèvre. Faites vous plaisir. Audio GD Master 10 ,he 7r2r ladder dac,auralic aries G2, JM lab Diva Utopia. Cordialement
Sérénité du rendu sonore
Le titre en dit long.
Ce CS est nuancé, clair, avec effectivement des silences impressionnants.
Couplé aussi avec les prises nfc Furutech, la musique est particulièrement apaisée.
Côté technique, le grave est simplement magnifique.
C’est cher, certes, mais je n’ai absolument aucun regrets.
Bluffant
Je ne cache pas que j'ai longtemps hésité avant de commander ce câble compte tenu de son prix. Mais franchement, couplé à des connecteurs furutech NCF rhodium, c'est simplement impressionnant. Le câble n'est pas encore rodé au moment où j'écris ces lignes mais sur mon préampli il a tout simplement pulvérisé mon câble HMS à 3 fois le prix. Bref, vivement recommandable mais je pense qu'il ne fait pas faire l'économie de connecteurs qualitatifs qui révéleront toutes ses qualités. Et a ce jeu les connecteurs NCF sont vraiment au dessus du lot. Bravo Furutech. C'est pas donné mais le résultat est vraiment à la hauteur.
Ce qui frappe à l'écoute c'est l'impressionnante ouverture de la scène, l'aération et le contrôle. Les voix sont à tomber, gros gros silence et ça c'est fabuleux pour révéler une miriades de détails que je n'avais pas soupçonné sur des enregistrements que je connais depuis des années. Et je pousse le potard 2 cran plus loin sans que rien ne bouge, c'est vraiment impressionnant, très beau, très naturel, un excellent câble assurément.
 (3)
Specially for amplification
I prepared this cable with ETI Legato plugs Schuko and IEC, don't use FI-50 NCF like most people and distributors do. I had read, that sometimes with NCF sound isn't as floated and excellent, like with gold-plated Wattgate or other plugs. ETI are the best from I knew gold-plated plugs, so I matched them with DPS 4.1. The power cable I connected to power amplifier Audia Flight. Compared to TCS-31 the sound is more cultural, more smooth, more detailed, more precise, more weighed. The differences aren't dramatic, rather like progress in all aspects. But if you want to find even the small progress, if money aren't problem, then the cable with good plugs can improve your system and will give you smile on the face, when you'll hear more and more and always beautiful.
 (5)
This Furutech DPS4.1 power cable is designed with a 79 / 0.18α-OCC conductor, a 37 / 0.18α-DUCC conductor as well as a 42 /...
