VIABLUE SC-6 Bi-Wiring Loudspeaker Cables 3.0m (The Pair)
VIABLUE SC-6 Bi-wiring Speakers cables 3.0m (Pair)
By buying this product you get 65 loyalty points
Reference : 7267
659,00 €tax incl.
549,17 € tax excl.
The SC-6 speaker cable consists of 36 conductors totaling 684 strandsindependent.
In order to refine its sound characteristics for different frequency ranges, five beams have undergone silver plating for accurate and detailed reproduction of the treble and two beams have been tin plated.
The speaker cable SC-6AIRSilverhas 6pairs ofconductors,grouped by pair for cover the 3 frequencies: treble,mediums and low forall possible applicationsasa simple wiring, bi-wiring and bi-amplification.
Compared to a standard cable, the advantage of a 4-conductor speaker cable is its ability to reduce acoustic distortion.
Theof a traditional wiring between an amplifier and an enclosure, acoustic distortions appear, these distortions can bee generated by the oscillations of the bass signals which induce voltages in the cable.
The amplifier is not able to eliminate this phenomenon, these voltages can affect the signals carried and distort the reproduction of the various loudspeakers.
Bi-wiring consequently reduces interference between different frequencies.
They then appear only at the level of the amplifier where they can be effectively eliminated by the control circuits of the device.
Features:/ Strong>
  • The splitters used specifically on ViaBlue cables prevent the ends from breaking while providing robust and optimal guidance of each conductor
  • The exterior of the cable is protected by a braided nylon ViaBlue, the aesthetics of which at first glance show the care taken in the manufacture of this high-end speaker cable.
  • Thethe ends of the cables are crimped with gold-plated, gold-free OFC (oxygen-free) ferrules, in this way copper gets very little in contact with air, which ensures stable quality for several years and constant sound properties .
  • Bananas Gold plated T6s included
Technical data:
  • Conductor diameter: 15 mm²
  • Total diameter: 26 mm
  • PVC Insulation
  • Deoxygenated copperr to 99.99999%
  • Silver Plating
  • Capacity: 98 pF / m
https://www.audiophonics.fr/images2/7266/7266_VIABLUE_SC-6_BI_WIRE_1.jpg
All iaBlue cables are manufactured and handmade in Germany
Diameter (mm)26
Max length3m
PlatingGold
ConfigurationBi-Wiring
Colissimo - TNT - SoColissimo
