Ces câbles m'ont fait passer du 4/3 au 16/9, d'un LCD 46" à un écran 4K Oled 55". J'avais déjà un beau rendu, j'ai le cinéma scope maintenant.
By buying this product you get 38 loyalty points
These 1877Phono Zavfino Nova-SPK banana speaker cables are positioned on a top-of-the-range cable segment, designed to offer exceptional performance thanks to flawless signal transmission. To do this, no design step is left to chance and the selected components are processed to provide their full potential.
The Nova-SPK integrates single-crystal PC-OCC Copper Litz conductors with a cross-section of 12AWG / 3.31mm². These ensure excellent audio signal transmission due to optimal conductivity. The Litz yarn structure considerably reduces the skin effect. These conductors also benefit from a silver plating to increase conductivity even further.
The conductors have a double dielectric isolation to drastically limit harmful interference to the audio signal and sound reproduction. In addition, the cable has two large EVA splitters to reduce vibration.
This is a cryogenic treatment at two temperature levels, -186°C and -196°C, depending on the nature of the material used. This treatment optimizes the conductor crystals with the sole aim of providing the best possible transmission of the audio signal.
After extrusion, Nova-SPK Copper goes through a thermal high voltage surface cleaning process, close to electrolysis and more efficient than cleaning with a conventional cleaning agent. The result is a very pure conductor and the extraction oils and surface heating residues are completely eliminated. This process also makes it possible to obtain a ready-to-use cable, already ground in and offering an optimal result from the first musical notes on a high-end HiFi system.
Technical carateristics
SpEcifications | |
Product type | Speakers cable |
Length | 2.5m |
Connectors | Banana gold plated 24k" |
Conductors materials | PC-OCC Copper (Litz wire) |
Section | 12AWG (3.31mm2) |
Conductors plating | Silver |
Conductors pin plating | Gold |
Insulation | Dual dielectric |
Sheath | PVC (105c) |
Protection sheath | Braided fiberglass |
Splitters | EVA (anti-vibrations) |
Cable diameter | 17mm |
Splitters diameter | 35.3mm |
Coulor | Black, purple and silver |
Quantity | Sold by pair |
Length (m) | 2.5 |
Shielding | Yes |
Section (mm²) | 3.30 |
Connector | Banana |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | Silver |
Average votes 4.9 / 5 8 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Hervé F.
Cedric M.
Fabian b.
Quoc Quan T.
Stéphane C.
