1877PHONO OCC SILVER DART Speaker Cables Bananas OCC Copper / Silver 2.5m (Pair)
1877PHONO OCC Silver Dart banana Graphene speaker cables 5mm² 2.5m
The 1877 Phono speaker cable is a major advance in the design of analog cables. Taking all the mechanical, electrical and magnetic criteria influencing the final result, the Silver Dart Zavfino series offers the best components of the Graphene, with OCC copper and silver strands adjusted with the greatest precision for a natural and balanced result.
By buying this product you get 259 loyalty points
Reference : 12527
2 590,00 €tax incl.
2 158,33 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
-1877PHONO Silver DART OCC GRAPHENE-
The Silver Dart OCC speaker cable is the result of 3 years of development and testing on the mechanical transmission aspect, EMI RFI pollution and the quality of the materials used. The Silver Dart OCC GRAPHENE OCC GRAPHENE speaker cable offers today a quality of reproduction equivalent to the best High End productions on the market, capable of being compared to American and European references.
The H-Wound structure is a spinning technique that allows a high quality filling rate of 16,000 spirals/turns per meter without losing any strands during the manufacturing process.
This high precision assembly and clamping precision guarantees the same number of strands, the same cross-section at each conductor right up to the end of the final connection, which any passionate amateur can expect from a high-end loudspeaker cable. This high resolution loudspeaker cable includes a manufacturing of the cable in the cable between the sheathing part, classic EMI protection separated by two layers of cotton strands acting as a mechanical anti-vibration decoupling with the Graphene conductive and dielectric part of the cable.
The Silver Dart series conductors and wires are made of high purity OCC copper and OCC silver with multiple treatments :
1 DEEP CRYO TREATED : A Cryo treatment at two different temperature levels (-186° and -196°) depending on the nature of the materials used, optimizing the crystals of the conductors, always with the sole aim of providing the best possible signal transmission.
2 ULTRA SONIC 7 : After extrusion, the strands of the Siver Dart pass through a thermal process of surface cleaning by high voltage close to the electrolysis more efficient than a simple cleaning by a conventional cleaning agent. The result is high purity, completely removing the extraction oils from surface heating residues. This process also makes it possible to obtain a ready-to-use cable already ground and offering an optimal result of the first music notes on a high-end Hifi system.
3 GRAPHENE DIELECTRIC ZGRAPH LDP : 1877 PHONO ZAVFINO is the world's first manufacturer to integrate screen protection with graphene, the leading edge materials against EMI/RFI references offering a high level of micro detail. Graphene is also an excellent protector against electrostatic discharges affecting the signal circulating on the surface of the strands.
You will find a full PDF article in English on the Graphene advantage: 1877 PHONO DART Graphene cable shielding technology
Technicals specifications :
  • material  : OCC monofilaments Cristal H Wound™ topology
  • Section : 5mm² (10AWG) / H-Wound™
  • Graphene dielectric high quality EMI RFI shield
  • Conductors Cryo treatment -196°
  • 2 split coton tube
  • One antistatic sleeve
  • Anti-vibration EVA cable finishing
  • Outside cable diameter : 24mm
  • Connectors : BFA banana standart
  • Length: 2.5m
1877PHONO Silver Dart OCC
Length (m)2.5
ShieldingYes
Section (mm²)5.00
ConnectorBanana
Conductors material (Cable)Silver
The 1877 Phono speaker cable is a major advance in the design of analog cables. Taking all the mechanical, electrical and magnetic criteria...
