1877PHONO THE SPIRIT ST Phono Cable DIN female 5 Pin - 2 RCA Black 1.5m
1877PHONO "THE SPIRIT" Cable Phono DIN female 5 pin - 2 RCA
Reference : 4721
159,00 €tax incl.
132,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
The cable "THE SPIRIT"of the Canadian brand1877 PHONOallows to connect your reading arm with connector5 Pinson a Phono preamplifier with RCA plugs *.
Resolutely Audiophile in its design, it is especially useful for connecting old record players to our modern equipment, leaving them an additional chance to amaze us by their inimitable analog sound.
D'a rare elegance with its black nylon sheath streaked in white and its satin-like connectors, the SPIRIT testifies to the love of its designers for beautiful things, whether visual or auditory.
MIt also testifies to the seriousness of their approach on the technical considerations: Thus the DIN and RCA plated with fine gold 24k andTeflon insulated , while each link is made with the aid of welding containing 5% silver.
The cable itself encloses 4 copper conductors OFHC silver plated section 0.40mm², surrounded by shielded copper braid, itself covered with a protective anti-static PET layer(Polyethylene Terephthalate ).
It is therefore with a certain pride that AUDIOPHONICS has become the exclusive distributor of 1877 PHONO products for France
* NOTE: This cable can not be used to connect a turntable to a conventional line input (CD, TAPE, AUX ...). In order to operate, it requires an input on RCA sockets of higher sensitivity, usually accompanied by a grounding, and leading to a correction filter conforming to the RIAA standard. This type of input is generally labeled "PHONO" or "TURNTABLE" on integrated preamplifiers and amplifiers.
Specifications:
  • Number of Drivers: 4
  • Composition of Conductors: OFHC Copper Plated Silver Section 0.40mm²
  • Input: DIN 5 Pin Gold Plated 24k Plug & Insulated Teflon
  • Output: 2 RCA Plugs + 24k Gold Plated Ground & Isolated Teflon
  • Shielding: Copper + Insulation Sheath PET ( Polyethylene Terephthalate )
  • Total Cable Length: 1.50m
  • Finish: Black & White Nylon Sheath
Length (m)1.5
ShieldingYes
Section (mm²)0.40
ConnectorRCA
Amélioration notable
Dans l’optique d’améliorer le système phono depuis la platine, la tête de lecture jusqu’aux enceintes, j’ai acheté ce câble en remplacement du câble d’origine sur une platine phono Transrotor, Et
Je dois dire qu’une fois encore dès la première écoute j’ai été étonné, il me semble avoir gagné nettement dans les aigus essentiellement. Étant donné le prix de ce câble, c’est un élément essentiel pour améliorer toute la chaîne d’écoute.
Thierry
This review has been posted for 1877PHONO THE SPIRIT ST Phono Cable DIN female 5 Pin - 2 RCA Black 1.5m
