CANARE 4S6 STAR QUAD Speaker cable Copper 4x0.5mm² Ø6.4mm
CANARE 4S6 Star Quad Speaker cable Copper 4x1mm² Ø 8mm
The Canare 4S6 speaker cable with starquad technology offers professional audio quality and reliability at an affordable price. It is very useful for designing low-quality speaker cables, as well as for internal speaker wiring.
4.9 / 5
Reference : 12593
1,80 €tax incl.
1,50 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
Here is the CANARE 4S6 cable, a perfect loudspeaker cable for good quality, low-cost two-wire cabling. The latter has 4 high quality copper conductors with a very long service life. Its unique PE (Polyethylene) insulation and Star Quad configuration provides protection against electromagnetic interference (EMI) from the speakers.
It is possible to use it naked, if you want to add endings, we recommend forks and bananas of similar quality, with OFC copper, non-oxygenated, for example.
Features:
  • 4 annealed copper conductors
  • 4 x 0,5mm² (section) (20AWG) or 4 x 1.87mm (diameter)
  • Total cable diameter: Ø 6mm
  • PE insulation: polyethylene
  • PVC body: durable and flexible
  • Sheath colour: grey / black
  • Sold by the meter
CANARE 4S6 MECHANICAL SPECIFICATIONS
Diameter (mm)6.4
Length (m)Sold by length
Number of conductors4
Insulation materialPE
ShieldingNo
Section (mm²)1.00
Ground / ShieldingNo
10 reviews
fou !!
Le meilleur câble que j'ai écouté ! le secret est de le doublé ! ( 8 brin pour le + et 8 autres pour le -) ! comme ça, respect de l'impédance !
ainsi monté, la bande passante est incroyable !
On m'a prêter souvent des câbles hors de prix, mais celui la est au dessous de tous ! foncé !!
This review has been posted for CANARE 4S6 STAR QUAD Speaker cable Copper 4x0.5mm² Ø6.4mm
Used it for DC, connecting power supply to DAC
Replaced the 80 cm standard DC power cable with a 40 cm Canare 4S6 SQ cable. Results were above expectations. Recommend for DC applications.
Switchlink cable for silent angel switch
Very good cable, I use it as a power supply cable between my silent angel bonn n8 ethernet switch and the 5v. linear power supply.
Way better than the standard cable
Excellent
Clarté,fluidité,sensation d'aisance sur la large bande passante,ne favorise aucun registre,image stéréo idéale sur mon modeste système,preuve qu'en matière de câble on peut avoir l'excellent à petit prix.Très satisfait d'audiophonics.
Très bon
Depuis 25 ans j'utilisais les mêmes
câbles hp entre un ampli marantz thirty et des enceintes kef105. Avec l'installation d'une alimentation ipower pour le petit dac Audiophonics (tous deux recommandables) cela a mis en exergue les limites du câble. Sur les conseils de David, j'ai commandé ce câble hp qui ne m'a pas coûté plus cher que le port. La différence s'est avérée d'emblée flagrante, avec un naturel et un équilibre remarquables. De même sa petite section ne l'empêche pas de contrôler parfaitement le hp de 30 cm . Ne croyez donc pas que la qualité d'un câble est proportionnelle à son prix, en voilà la preuve. Merci David et Audiophonics.
The Canare 4S6 speaker cable with starquad technology offers professional audio quality and reliability at an affordable price. It is very useful...
