ELECAUDIO HP-25OCC Speaker Cable OCC / OFC Copper PTFE Insulated 2x5.1mm² Ø7.5mm
ELECAUDIO HP-25OCC Câble HP OCC/OFC Isolé PTFE 2x4.8mm² Ø7.5mm
Elecaudio offers a new version of this high-end cable based on the same technical logic that made its success but now optimized to offer great flexibility. This uncompromising high-end speaker cable uses a mixture of OCC copper wire in the center and OFC around it, in order to obtain a balanced result.
4.7 / 5
Reference : 5477
13,90 €tax incl.
11,58 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
Câble vendu au mètre
Elecaudio HP-25OCC
Speaker Cable OCC / OFC Copper Isolated PTFE 2x5.1mm² Ø7.5mm
Elecaudio HP-25OCC Câble HP OCC / OFC Isolé PTFE 2x5.124mm² Ø7.5mm
The OCC core in the center of the cable is now made of 6*0.126mm² wires. The OFC wires are now 546*0.008mm². The two conductors are maintained by the sheath at a distance of 10mm from each other. The thin strands give the cable good flexibility while the configuration limits the height to only 7.2mm.
For a perfect osmosis, we recommend the modulation cable Elecaudio SC-221OCC and Elecaudio SC311OFC Watersound.
Product typeSpeaker cable
ConductorsOCC Copper : 6*0.126mm²
OFC Copper : 546*0.008mm²
Section2*5.1mm²
Diameter / cableØ7.5mm
InsulationPTFE
External sleevePVC
Total width19mm
QuantitySold by the meter
Diameter (mm)7.5
Length (m)Sold by length
Number of conductors2
Insulation materialPTFE
ShieldingNo
Section (mm²)5.1
Ground / ShieldingNo
56 reviews
Good but not perfect.
I bout this cable for making a jumpers - 0,6cm long. After more than 100hours burning, i have to say this - smooth, warm, less dynamic and less clear. I check them like this - i swithed speaker cable between terminals, what will be. When signal runed directly - that drivers been fast, clear, dynamic, expresive. When signal runed by jumpers, everything geting slower, less volume, less details, less dynamic, and etc. As if i put there 100m long cables or etc. Unfortunately, for my using, not good. After i made jumpers from Kimbre Kable - 24T, and this is totaly different, totaly opposite.
This review has been posted for ELECAUDIO HP-25OCC Speaker Cable OCC / OFC Copper PTFE Insulated 2x5.1mm² Ø7.5mm
Câble fantastique
Je possède ces câbles HP depuis bientôt un mois et après une vingtaine d'heures de rodage, je confirme que ce câble est extraordinaire au regard du prix.
Je possédais avant des câbles Viard Audio HD 20 qui sont 18 fois plus cher et franchement ces Elecaudio associés à des fiches Viborg font jeu égal voir mieux que les Viard Audio.
Inutile de dépenser plus pour avoir mieux et pourtant mon système est assez haut de gamme.
Merci à Mr Aubert pour ces conseils .
Révélateur de talents !
Je viens d’un câble Supra 2.5, équivalent du Jantzen vendu par Audiophonics. Que dire de cet Elecaudio HP-25OCC ? En résumé il laisse passer le signal avec le moins d’altération possible (transparence). Et c’est ce que l’on demande avant tout à un maillon intermédiaire dans un système audio.
Côté mise en œuvre, j’ai utilisé des fiches bananes QED qu’il me restait en stock (j’ai été pro dans un lointain passé). Celles qui se sertissent sur le câble avec une pince spéciale afin d’obtenir une « soudure à froid ». Comme les manchons de ces fiches QED ne passaient pas sur la gaine du câble Elecaudio (très grosse), alors je les ai remplacées par des gaines thermo rétractables blanches et rouges (esthétiquement ça réagit très bien sur la gaine noire du câble).
En amont le système est composé d’un Oppo 105D que je n’utilise plus que pour lire CD et SACD, couplé à un DAC Gustard X16. Ils sont liés en I2S via HDMI (grâce à l’adaptateur acheté aussi chez Audiophonics). En préampli un Marantz AV7706 et en amplification : Audiophonics MPA-S250NC XLR. Les câbles modulation (RCA et XLR) sont des Neotech NEI 3004. Les enceintes sont des Focal Aria 936.
Je confirme qu’il faut une période de rodage d’une bonne dizaine d’heures (voire un peu plus).
Résultat du changement des câbles HP ? On y gagne partout : respect des timbres, ouverture et profondeur de la scène sonore, ambiances de salles, micro informations beaucoup plus audibles. Ça respire ! Et en corollaire, on gagne aussi sur l’intelligibilité de la restitution. Tout s’entend mieux, tout se comprend mieux. La géométrie de la scène sonore est respectée. Je veux parler du placement des instrumentistes et des voix, mais aussi de leur volume propre. Alors évidemment, si l’ingénieur du son à voulu mettre en avant la voix au détriment de l’accompagnement instrumental, ça ne va rien y changer, mais s’il s’agit d’une prise de son stéréo d’un ensemble, alors oui, clairement, tout est bien à sa place et dans le volume propre à chaque voix/instrument. Très franchement, ce câble est un révélateur de talents. Alors, si vous souhaitez profiter à plein de votre système, faites l’essai pour vous faire votre propre opinion. Mais a priori vous ne devriez pas le regretter.
Bluffant
J’ai acheté ses cables il y a trois semaines, et après pas mal d’heures d’écoute, ils rivalisent Très nettement, avec le câble, Viard HD 20, qui il faut le rappeler est Environ 50 fois plus cher !
Ça paraît à peine croyable, mais c’est vraiment ce que j’ai constaté.
Thierry
Wow!
A great product. Both channel attached to each other, which was fist odd to me. But easy to handle, light, flexible, easy to cut appart. Large diameter (wires). I think it sounds great. Very homogenous, over all (treble, middle, low/bass), airy, nice resoloution. At least everything you need. A bang for the buck.
Elecaudio offers a new version of this high-end cable based on the same technical logic that made its success but now optimized to offer great...
