ELECAUDIO HP-25OFCS Speaker Cable Silver Plated OFC Copper PTFE Insulated 2x5.1mm² Ø7.5mm
ELECAUDIO HP-25OFCS Speaker Cable Silver Plated OCC Copper PTFE 2x5.1mm² Ø7.5mm
The renowned Elecaudio HP-25OCC speaker cable is back in a new version, even more efficient, the HP-25OFCS. This one takes the same technical logic that made the success of its predecessor but integrating here even more efficient conductors. This high-end speaker cable uses high purity silver-plated OFC copper to ensure maximum electrical conductivity.
Reference : 17098
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
Câble vendu au mètre
Elecaudio HP-25OFCS
Speaker Cable Silver Plated OFC Copper PTFE 2x5.1mm² Ø7.5mm
Elecaudio HP-25OFCS Câble HP Cuivre OFC Plaqué Argent Isolé PTFE 2x5.124mm² Ø7.5mm
Each conductor is composed of a core of 6 strands of silver plated OFC copper with a section of 0.126mm².  This core is then surrounded by 546 strands of silver plated OFC copper with a section of 0.008mm². The two conductors are insulated with a PTFE sheath and then covered with a robust PVC sheath and maintained by the central sheath at a distance of 10mm from each other.
Product typeSpeaker cable
ConductorsSilver plated OFC copper: 6*0.126mm²
Silver plated OFC copper: 546*0.008mm²
Section2*5.1mm²
Diameter/cableØ7.5mm
InsulationPTFE
Outer sheathPVC
Total width19mm
QuantitySold by the meter
Diameter (mm)7.5
Length (m)Sold by length
Number of conductors2
Insulation materialPTFE
ShieldingNo
Section (mm²)5.1
Ground / ShieldingNo
5 reviews
2eme avis
Les basses sont devenues plus propres et bien présentes. Ce câble nécessite un certain temps de rodage pour se placer...
This review has been posted for ELECAUDIO HP-25OFCS Speaker Cable Silver Plated OFC Copper PTFE Insulated 2x5.1mm² Ø7.5mm
Petit cr
En remplacement du Mogami w3103, sur un ampli classe d 3e audio pffb, définition et ouverture supérieur tout en gardant le même timbre mais manque de basses fréquences.
Sur ampli a tube kt88, il lui est supérieur a tout les niveaux.
En résumé, ce câble est moins suave et "musical" que le mogami mais est nettement plus défini. C' est une affaire de goût et de combinaison système.
Je l' ai monté avec des fiches bananes elecaudio cuivre plaqué argent soudé avec mundorf suprême 10%.
Câble recommandable mais prochain test, ce sera du neotech occ ou mundorf angélique..
Très bon câble
Le contexte :
Après avoir monté des pieds Kanto de 81 cm sous mes enceintes Blumenhofer Satellite Mini, initialement posées sur mon bureau, j'ai dû remplacer mes câbles MaxiTrans II de 2 fois 2,5 m par des câbles de 3.5 m au moins pour les relier à un Marantz Amp1. J'ai donc acheté 8 m de ce câble pour avoir 2 x 4 mètres et donc un peu de marge et je l'ai monté avec des fiches Bananes ETI KRYO.
Le montage :
Le câble est très épais avec une forte section et, si vous prévoyez un connecteur fourche ou fiche banane, assurez vous qu'il est assez grand (le ETI est limite). Sinon le montage est facile : dénuder le câble ne pose pas de problème particulier, le couper non plus (un gros ciseaux suffit).
A l'écoute :
J'étais persuadé que la notion de rodage était réservée aux moteurs de voiture, mais avec ce câble, je constate une très grande évolution après quelques heures d'utilisation : quelques fréquences stridentes se sont calmées et l'écoute est de mieux en mieux et globalement très bonne.
Conclusion :
Très bon câble avec un rapport qualité prix favorable, fortement recommandé si l'on cherche un câble dans une gamme de prix allant jusqu'à 50 euros le mètre, voire plus.
 (3)
ELECAUDIO HP-25OFCS Câble
Excellent price-performance ratio and the right combination of copper and silver for dynamic and clear sound. Terminated with ATOHM WT-STU Plugs this cables are very good solution for Class D amps . A new reference for me.
 (4)
top
Premières écoutes : Entre mon ampli Lector audio ZXT70 et mes enceintes Récital Define HEFA enterre le Mogami W3103 loin derrière.
Câbles très transparent, beaucoup plus de détails et de profondeur sur tout le spectre, les petites sibilances sur certains enregistrements difficiles ont disparues. Le couple cuivre/argent semble être adapté à mon système.
"C’est comme si on avait enlevé un bouchon. "
À recommander!
(du moins chez moi)
 (5)
The renowned Elecaudio HP-25OCC speaker cable is back in a new version, even more efficient, the HP-25OFCS. This one takes the same technical logic...
