FURUTECH FS-15S Loudspeakers Cable µ-OFC (SolidCore Alpha) 2x1.6mm² Ø8.2mm
FURUTECH FS-15S Loudspeakers Cable µ-OFC (SolidCore) 2x2mm² Ø 8.2mm
Reference : 11149
53,90 €tax incl.
44,92 € tax excl.
Shipping from France
Billing in France
Technical support in France
This FURUTECH Alpha FS-15S loudspeaker cable with copper µ OFC single strand is an original solution with the α Alpha cryogenic antimagnetic treatment from the Japanese brand. This is a speaker cable with a special design that provides precision and a detached bass register, stretched with solid bass. The Solid-Core monobrand design fused with Alpha technology will provide a very pleasant three-dimensional sound image.
A cable that will be a palliative for rooms with recalcitrant acoustics, invasive bass or for naturally generous speakers in this range. Thanks to the Japanese brand's exclusive α Alpha surface treatment, the precision of the sound scene is not to the detriment of the timbres.
A well-designed 2-conductor loudspeaker cable designed by a Japanese brand renowned for its reliability, which is in line with FURUTECH's production continuity.
The quality of top-of-the-range mechanical assembly offers a most convincing result when listening. A speaker cable that will perfectly match the following high quality banana and fork plugs:
Characteristics:
  • 1 Red conductor and another white conductor (surface treatment α Alpha) 1.5mm Copper.
  • Insulation of conductors: Foamed polyethylene (AIR FOAMED), fluoropolymer and cotton.
  • Shielding with aluminium strap and Alpha treated conductor 7 strands x0.2mm.
  • Envelope: PVC hose (green sheath).
  • Maximum resistivity: 0.01 Ω/ M.
  • Outer diameter: 8.2mm (15 AWG).
Length (m)Sold by length
Number of conductors2
Insulation materialOther
ShieldingYes
la grande surprise
je cherchais un câble pas très volumineux mais ne bridant pas la capacité en courant de mon ampli ML de 50 kg. relativement abordable et me fiant au site du constructeur, je me suis laissé tenter. après une dizaine d'heures de rodage ce fut la grande surprise. ce câble est très Équilibré avec un grave massif, un médium insuflant une belle présence et un aigu très bien intégré. dynamique plus que correcte, mais la cerise sur la gâteau est l'image sonore bien développée dans les 3 dimensions. du coup il a remplacé mon câble phono prima, un peu trop sec à mon goût et difficile à loger derrière un meuble. très polyvalent
 (3)
This review has been posted for FURUTECH FS-15S Loudspeakers Cable µ-OFC (SolidCore Alpha) 2x1.6mm² Ø8.2mm
