SOMMERCABLE MERIDIAN SP225 FG Speaker Cable OFC Copper FRNC Shielded 2x2.5mm² Ø 8.3mm
SOMMERCABLE MERIDIAN SP215 FG Speaker cable OFC 2x1.5mm² Shielded Ø 8mm
Reference : 9922
5,80 €tax incl.
4,83 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
SOMMER CABLE - SC-MERIDIAN SP225 FG
Where it's going or not ...
the acousticians are at work: they do not spare the cables, because they never have time to take precautions. This sturdy cable is specially designed for the connection of speakers and technically satisfies all the requirements. Its low oxygen copper cores ensure excellent acoustic characteristics and long service life. All versions with PVC sheathnt easily rollable. The variants SP215 and SP225 are now equipped with very flexible cores composed of 0,15 mm copper strands!
New versions: FRNC and E30 (according to IEC228, IEC332- / 1, IEC 332-3 Cat C, IEC 60331, IEC 61034-1 / 2, IEC 60754-2) and the OFFROAD version olive green "MAJOR INVISIBLE" with an actual section of 2 x 2.5 mm².
Another new feature is the MERIDIAN FG armored version, for indoor and outdoor installations, with double screen (copper braid and AL sheet) and a halogen-free, flame-retardant outer sheath (classification IEC 332.3). Because of its composition, this version is not suitable for mobile applications.
ADVANTAGES:
  • Flexible (PVC and PUR versions) and easily rollable
  • Low diameter
  • Long service life, due to the special sheath
  • Competitive price
  • Also available in PMB, FRNC and shielded versions
USE:
  • Various acoustic installations
  • Fixed installation, also for E30 and FRNC versions
  • For the ELA technique
  • Wiring of hi-fi systems
  • External mobile employment (PUR version)
Specifications:
Constitution(2LIY2,50mm2) Y
diameter 8.3 mm
AWG13
Number of Conductors2 x 2.5 mm2
Envelope material, insulation FRNC (mode C)
Copper strands per core 50 x 0.25 mm
Conductor insulation, diameter 3.05 mm
Operating temperature min. -30 ° C
Operating temperature max. 70 ° C
Weight per m
Colordark gray
Electrical Specifications:
Capacity metric cond./cond.136 pF
Odometer Resistance, Conductor<7.5 Ohm
Resistance, insulation> 5 MOhm
Diameter (mm)8.3
Length (m)Sold by length
Number of conductors2
Insulation materialPVC
ShieldingYes
Section (mm²)2.5
Ground / ShieldingYes
3 reviews
Très bien
Utilisé pour un câble hx16 marche bien pour le prix
This review has been posted for SOMMERCABLE MERIDIAN SP225 FG Speaker Cable OFC Copper FRNC Shielded 2x2.5mm² Ø 8.3mm
Un excellent câble
J'avais besoin d'un câble pour mon second système composé d'un ampli et préampli séparés Rotel série 971 mk2 et d'une paire d'enceintes Réga EL8 , et je reste donc toujours aussi satisfait de ce produit que je recommande...
Bon
Utiliser avec des enceintes monitor audio apex. Que du bonheur
