OYAIDE HPSC-35J Male Jack 3.5mm to Female Jack 3.5mm Copper 102SSC Silver / Rhodium Plating 1.3m
OYAIDE HPC-35J Câble Jack Femelle 3.5mm 1.3m
This superb high-end cable is equipped with a 3.5mm male jack connector on the one hand and a 3.5mm female jack connector on the other. It will be particularly useful to take advantage of an extension of a headphone cable that is too short by acting as an extension cable. The materials used for this HPSC-35J contribute to a significant improvement in reliability and sound quality.
Reference : 7737
95,00 €tax incl.
79,17 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
Oyaide HPSC-35J
Oyaide HPSC-35J Câble Jack 3.5mm mâle vers Jack 3.5mm Femelle Cuivre 102SSC Plaquage Argent / Rhodium 1.3m
The cable conductors are made of high-purity 102 SSC Copper and each connector is plated with Silver and Rhodium to ensure excellent conductivity and durability. The conductors are insulated with TPE sheath and 102 SSC 100/0.12 shielding to significantly reduce unwanted interference. The cable is assembled with a high quality SS-47 weld. Unlike conventional soldering, which uses 3N (99.9%) of pure tin, the SS-47 uses 4N, i.e. 99.993% of pure tin, thus excluding a maximum of impurities. In addition, this solder also contains 4.7% Silver and 1.7% Copper.
Product typeJack cable
Connectors1x Male Jack 3.5mm
1x Female Jack 3.5mm
Length1.3m
Conductor materialCopper 102SSC 60 / 0.08
Connectors platingSilver 1.5µ + Rhodium 0.3µ
InsulationTPE
Shielding102 SSC 100/0.12
Insulation resistance20°C / 10MΩ-km
External sheathBraided silk
ColorCable : Black and white
Connector : Silver
Cable diameter4mm
Connectors diameterMale Jack 3.5mm : 8.5mm
Female Jack 3.5mm : 9.3mm
Length (m)1.3
ShieldingYes
Section (mm²)0.0810
ConnectorJack 3.5mm
This superb high-end cable is equipped with a 3.5mm male jack connector on the one hand and a 3.5mm female jack connector on the other. It will be...
