1877PHONO ARCANA HYBRID Interconnect Cable OHFC / OFC RCA-RCA 1.5m
1877PHONO ARCANA HYBRID Interconnect Cable OHFC/OFC RCA-RCA 1.5m
Arcana 1877PHONO cable has an excellent manufacturing and finishing with quality Cinch RCA with OFC central pin, a high purity copper surface treatment and dual EMi RFi shielding.
4.8 / 5
Reference : 12543
95,00 €tax incl.
79,17 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
- THE ARCANA Hybrid -
OHFC / OFC
The 1877 Phono Arcana-Hybrid modulation cable is developed for the most demanding analogue systems of yesterday and today. The construction consists of a twisted pair of tightly braided fine wires in a HPE (polyethylene) sheath and a non-capacitive dielectric for faultless and distortion-free signal transfer. Arcana uses a multi-shielded Mylar foil construction and a tight pitch braid for 100% coverage against EMI and RFI interference. Externally, the cable uses a ROHS-certified PVC sheath followed by a black high-strength pure anti-scratch/anti-static nylon braid.
The bare conductor of the Arcana is treated by the Ultra Sonic cleaning process. The raw copper passes through an electrically charged water bath to burn dirt, oil, particles and impurities on the wire surface. This ultra sonic bath also has the unique effect of pre-grounding the cable instantaneously which would take hundreds of hours to achieve by normal use.
1877 Phono High quality RCA OCC copper pin
The 1877 PHONO brand, renowned for its power supply and modulation cables, designs and manufactures its own Hifi connection technology. Unlike many manufacturers using 1877Phono external brands, 1877Phono has mastered all electromechanical aspects from one end of the cable to the other, offering a formidable value for money with RCA plugs with OCC copper central pin, PTFE insulation and 24k gold plating.
Technical Specification
Type câble modulationStereo Cable RCA hybrid copper strands
RCA ConnectorsRCA 24K gold-plated copper central pin OCC type Zavfino 1877 PHONO ZSP-7 PHONO ZSP-7
IsolatingHPE Polyethilene
Wire conductor materialTwisted twisted OHFC and OFC hybrid braided strands
Copper surface treatmentUltra sonic 7 electrolysis treatment
External screen EMI RFI Aluminum mylar foil and OFC braided copper sheathing
Finishing sleeveNylon and polyester abrasion resistant
Length1m50
DeliveredA pair
Length (m)1.5
ShieldingYes
Section (mm²)N/A
ConnectorRCA
4 reviews
Very good Interconnects
I was not expecting these to be as good as they are. They have made a very positive contribution to my system especially to the sound of my DAC which sounds a lot more coherent and well-balanced than before. It had been connected with more expensive cables previously..
This review has been posted for 1877PHONO ARCANA HYBRID Interconnect Cable OHFC / OFC RCA-RCA 1.5m
Très bon rapport qualité prix
Un grand bravo pour cette excellent câble de modulation , il est certain qu’il n’a pas à rougir de la concurrence beaucoup plus cher. Je l’ai comparé avec deux câbles , celui à 135€ est moins bien et il égale un autre câble à 250€.
Cela laisse songeur et confirme qu’il n’est pas nécessaire d’acheter des câbles très chers du moment que votre système est en place. Il suffit d’un bon zavfino à 85€, ce câble laisse s’exprimer la musique de belle façon .
J’ai d’ailleurs les câbles hp et jumper de cette même marque que je recommande chaleureusement à tout les mélomanes ayant la chance d’avoir de bon système d’écoute .
Chapeau bas zavfino et merci à audiophonics qui propose d’excellent produits avec un rapport qualité prix remarquable.
Bonne écoute
arcana hybrid 1877
unfortunately i cannot review product as it was stolen whilst in transit in england.
excellent cable pour le prix
ce n'est pas un premier prix mais il est raisonnable par rapport à la qualité de fabrication. A l'écoute et par rapport à un cable phono moyen ( 59€ ) la bande passante semble plus large avec une meilleure profondeur et un grave mieux tenu. Je n'ai pas remarqué de différence notable avec un cable nettement plus cher( 169€ ) que j'ai sur un autre ensemble.
Arcana 1877PHONO cable has an excellent manufacturing and finishing with quality Cinch RCA with OFC central pin, a high purity copper surface...
