SOMMERCABLE EPILOGUE OFC Copper RCA Interconnect Cable Shielded Gold Plated 1m (Pair)
SOMMERCABLE EPILOGUE Cordon de Modulation RCA 1.0m (La paire)
Sommercable's RCA Epilogue modulation cable has been designed to contribute to neutral and faithful sound reproduction, promoting a wide sound image thanks to excellent signal transmission. Ideal for sound professionals and recording studios, it is just as effective in a home HiFi system.
4.9 / 5
Reference : 7901
145,00 €tax incl.
120,83 € tax excl.
Shipping date: 24-04-2024.
Shipping from France
Billing in France
Technical support in France
Sommercable Epilogue
Sommercable Epilogue Câble de modulation RCA Cuivre OFC Blindé Plaqué Or 0.5m (La paire)
Thus, this Epilogue cable integrates high quality components. The outer sheath hides 4 100% insulated OFC copper conductors thanks to a triple shielding composed of a copper braid and semiconductor to limit the impact of interference on the signal. The conductors are smoothed with carbon for better conductivity. The cable design allows it to achieve a very low electrical capacity of 35pF, ensuring that there is virtually no loss over cable lengths of less than 10m.
The RCA connectors of this cable have PTFE insulation and are equipped with complex shielding. Its contacts are gold plated to ensure very good conductivity and resistance to oxidation.
Product typeModulation cable
ConnectorsRCA
Length1m
Cable diameter7mm
Conductor materialOFC Copper
Sheath materialPastic
Shielding material3 layers :
Braided Copper and semiconductor
Capacity35pF wire/wire (crossover)
Cable colorYellow
QuantitySold by pair (2 cable)
Length (m)1.0
ShieldingYes
Section (mm²)N/A
ConnectorRCA
12 reviews
Excellent
Je l'utilise avec un Audio-GD R7-HE21. Tout est parfait de l'extrème grave à l'aigu, pas de dureté. Cable franchement excellent.
This review has been posted for SOMMERCABLE EPILOGUE OFC Copper RCA Interconnect Cable Shielded Gold Plated 1m (Pair)
Très bon rapport Qualité/Prix
avec un peu de recul, je peux donner mon avis sur les câbles de modulation SOMMERCABLE EPILOGUE : utilisés entre mon DAC et mon ampli, ils sont fidèles au messages musicaux, pas colorés, plutôt neutres, RAS, font le job ! Comparés à mon câble TELLURIUM QBLACK (utilisés pour ma platine CD, ils sont excellents) les SOMERCABLE sont inférieurs mais restent bons. Toutefois, les Tellurium sont 4 fois plus chers...donc le SOMMERCABLE reste d'un très bon rapport qualité/prix.
jaune est la couleur de la musique
Que dire de plus que les avis précédents ? Une vingtaine d'heures de rôdage, sinon les premières écoutes sont quelconques. Puis vient l'effacement progressif de ces câbles, au profit d'une écoute plutôt neutre, large, respectueuse des enregistrements, du timbre et du grain des instruments (j'écoute des CDs classiques, jazz, rock, électro avec un ampli à tubes et un DAC d'entrée/milieu de gamme). Aigus pas agressifs, graves bien tenus et fouillés, contrairement au Neotech Nemoi 3220 acheté (presque 2 fois + cher que l'Epilogue) sur ce site, dont le grave est plus flou et la sonorité générale plus chaude. Essayé aussi en coaxial, avec les mêmes impressions qu'en modulation, cet Epilogue pourrait bien mettre fin à beaucoup d'achats et d'essais d'autres câbles pour bien des audiophiles comme moi.
Très bon
Mieux que mon cable Atohm
Moins de coloration, plus de détails, d'équilibre et de transparence. Ce cable apporte un bon changement à mon système : plus de naturel !
Très bon cable. A recommander!
Il relie l'ampli Moon i5.3 au lecteur réseau Cocktail Audio x45 avec succès: très bonne définition et de l'air entre les instruments.
Il fait un peu mieux que le Galileo diy 238+
 (3)
Sommercable's RCA Epilogue modulation cable has been designed to contribute to neutral and faithful sound reproduction, promoting a wide sound...
